glueing and clamps
glueing and clamps
glueing and clamps
Joseph Mulherin
When you do not have the correct length of clamps or not enough of them....try using an assortment of bungee cords. I reglued my first chair rockers into place on the seat using the bungee cords and it really did hold everything in place nicely.
Re: glueing and clamps
Don't forget the Spanish Windlass
Jason Waters
I've done it for odd stuff, and it does work well. Also, those ratching strap work well, you just have to make sure where the ratchet mechanism rest is sheilded with a piece of scrap or rags or something.
Good ole inginuity
Joseph Mulherin
I have used and still have those straps. but like my chairs...when you have say 8 jointsw to glue and align the bungee cords do the best for me. Align the joints and just stretch the cords out and hook on.
A good assortment do very nicely for almost every job imaginable.
Blue
I just finished glueing an ol' split in half wagon wheel together, no clamps around, used rubber bands, worked fine.
That's great Joseph!
Don Orr
I'll have to remember that one. Use what you have on hand. Neat idea.
Re: That's great Joseph!
Joseph Mulherin
Yes, Don I used two on the spreaders on the first rocking chair and it came out perfect...easy and quick to apply....crisscrossed them and they held four joints together overnight.
Was turning some back stantions this afternoon...got one almost finished when all of a sudden the middle cracked and flew off the lathe. Was only turning at a midium speed....must have been a flaw in the wood.
Other turning using the same wood have turned out good.... tomorrow is another day...oh, well...
Don Orr
Glad you weren't hurt by that flying piece of wood. And a good attitude to have when things don't go as planned. Keep at it.
Joseph Mulherin
Setup another turning piece in the lathe and did about 70% of it more slowly before quitting for the day.
Have this one to finish and one more of the same design, then I am changing the back stantions to a different design so I do not have to turn those longer pieces.
I am using my Shopsmith lathe duplicator to turn all of the dowels to the same design. Make the first one using the regular way of turning, then use that one for the model to turn the others..... two more long ones to finish today.
Joseph Mulherin
Finished turning the long stantions for the seat back corners. Arms fit into them with 2 turned dowels underneath. Now am setting up some more wood to turn for some more spacers and spreaders....all identical in the turnings by using the same design I made for the duplicator.
Now I have to remake the seat back design in a thicker material....the first one seemed too flimsy, so shall probably make it about 5/8" thick and new splats too. Two chairs are coming along fine....a little here a little there....then it is all completed soon.
Have a different design to work on for the next two chairs....much different, and the arms are going to be redesigned flatter with a scooping out for the arm to rest on.
These chairs are for family members for Xmas presents, so I have enough ....I hope...
Don Orr
Sounds like you are making good steady progress. I'm impressed that you are working so far in advance of Christmas. The rest of us usually wait til December just to get started. :D
Joseph Mulherin
Thanks, Don, the reason is that I have the six chairs to do...a new experience for me in building chairs....and once I get the specifics clear in my mind of just how to cut each piece I shall proceed with the other chairs. I have these two chairs...mostly copies of one we have in the house...and have decided to change to another design for the next two chairs...something along the Maloof chairs designs.
The time is needed to work on the chairs, then decide on how each will be finished color wise for each household decors.
Joseph Mulherin
OK, Don, I finished turning the last of the spreaders, spindles for the two chairs.
Seats, rockers, & arms are ready, just have to redo the center back design and splats for the two chairs....then assemble both....probably over the weekend.
For finishing I am thinking a dark walnut stain covered with say three coats of poly on the first chair and maybe a chestnut stain on the second. ..probably next week or so for that.
It has been an experience doing these and I do feel confortable with what i have accomplished so far...
started just after New Years with the idea, made some schetches, cut out the dowel patterns on some 3/4" wood to use on my Shopsmith duplicator, cut and glued up the boards(1"x4" spruce) for the individual lengths called for the items mentioned, cut them out on bandsaw, routed edges with 1/2" roundover bit, sanded smooth as I went along.....now things are ready for assembly.
Four more chairs are planned...two the same and the other different back designs and arms.
Joseph Mulherin
This morning I bought some more assorted bungee cords at HD, glued up the legs, rockers, spreaders...16 joints in all being held in line and stable with only 4 small cords.
Hey, guys, it does work great...try it.
Joseph Mulherin
Good day, guys/gals, well today I finished glueing all the parts of the first chair together, took some pictures, tried to send to WC using the EasyShare program thru Kodak....NOT...I do not understand these new cameras and their software programs so I have not sent any pictures.
Barry Irby sent me some instructions, tried to use them....failed in operation.
Guess I am just going to have to have some physically show me how to use them.
Second chair is ready to assemble the arms and seat back. A little more sanding on both will let me think about the color applications now. I set the time as being finished by Easter for these two chairs and it looks like I made it. Next two will be started in June with a different design all around.
My hat off off to you...
mdclor
for completing your first chair. I don't even think I would dare to try one. I am really going to enjoy it when you are able to post some pictures. The software can't be any more difficult than your chair. :D
Keep us current with your progress, pix or not.
Re: My hat off off to you...
Joseph Mulherin
Thank you, Sir, I shall try to find someone to clear me up on just how to send pictures from these new cameras... everyone else seems to understand, but this old man is just plain stupid I guess....
Carol
Not stupid, Joseph.
Think of it this way and then maybe you can find your difficulty.
Take the picture. Upload to your computer. Process the picture so it will fit here - file size and format. See FAQ's. Label and save it so you can find it.
Then log on to WC, and follow the instructions on the FAQ's about posting pictures.
From camera directly to WC doesn't work. It's take it, upload it, process it, label and save it, and then post it. Good luck.
Joseph Mulherin
Thank you, Carol, that is exactly what Barry told me to do, but somewhere in the transaction I forget things.
Shall try again. Have written down your instructions and Barry's but these cameras to mee are very confusing in their operations. Just have to learn is all.....
Joseph Mulherin
Doing the individual parts is easy using the bandsaw, but the seat took some thinking. I tried using the Fortsner bits down to various levels and sanded around them to try to even things out but that was not satisfactory in the final looks I wanted. Then I learned about the way Charles Neil does his seats using the table saw and a daddo blade setup. You can watch it by going to YouTube at his In the Workshop-Charles Neil. I tried it and did the two seats I have worked on these past three months...working at various times...not steadily. I must say they came out very nice and the sanding with the carbide donut wheel and another sanding disc on the angle grinder worked out easier than I had hoped.
Carol
Sounds like the first issue is to upload the picture to the computer. Concentrate on that. Your computer should recognize your camera as another drive. Go to the drive that is your camera, copy and paste the pictures into a file on your computer. Save as a jpg file. If you have a PC, use the Windows picture manager. I do that. Easy peasy to process the picture. From the Picture Manager, go to the file where you saved the pictures from your camera, and process them. Save them to the web display from the Picture Manager.
You can tell I completely ignore the camera software. Just treat the camera as a separate drive. Try that and let us know. Trust me, friend, if I can do this, any one can.
Joseph Mulherin
Spent about 10 minutes selecting and trying to upload the pictures of my chairs and one click and I lost everything....NUTS to these new cameras and their screwy programs. Just have to have someone else sit here and tutor me on how to use them. Pictures later....I hope
Joseph Mulherin
redid the backs of both chairs with just slats instead of the original design which I found out was limpy and would crack under use. Did final glue up this morning; then some final sanding and then start doing the finishing. I said earlier i would try to have both chairs finished by Easter and it looks like it might happen...or a little into next week. Sorry, I do not have any pics to show because of the previously mentioned problems.
Joseph Mulherin
Finished applying some woodfiller to some cracks in between wood, sanded smooth with my HF multi-sander and ROS. Have decided to apply some Minwax wood conditioner; color red mahogany stain and then apply Minwax furniture polish wax.
I got these two chairs finished by Easter as I said a long time ago. Have to check on the design for the other two chairs next.
Joseph Mulherin
I am gettijng really angry in that I cannot understand just how to send pics to this website so you people can see. And going to the local stores for some instructions is another frustrating event.
I go to the FAQs and read them on how to do things....but it does not translate into my brain on how to do them since I do NOT see the Upload or the "blue button". FRUSTRATION!!!! on how these things operate
