3 legged stool
3 legged stool
3 legged stool
dick gerard
Here is a shot of a 3 legged stool I just finished. Well, a few months ago. My 85 year old mother uses it to rest upon when she takes the dog out to its business.
Seat is maple painted with Old Fashioned Milk Paint and the legs are curly maple.
Let me know what you think.
Re: 3 legged stool
Re: 3 legged stool
John McGaw
Very pretty and quite graceful. I love the suggestion of knees on the legs whether it was intended or not.
Re: 3 legged stool
Re: 3 legged stool
Paul Leuba
Very nicely done. How did you get the angles correct and uniform on the legs?
Re: 3 legged stool
Re: 3 legged stool
Philip Duffy
Great execution on those legs- -getting them all pointed in the right direction and being able to keep the ball on the ground is great! My own success rate with this sort of thing is far less and I would love to see how you lined up and drilled the leg holes so accurately. Thanks for sharing.
Re: 3 legged stool
A Real Beauty
Re: 3 legged stool
Outstanding !
Don Orr
Or out-sitting I guess. Beautiful work.
Re: 3 legged stool
Re: 3 legged stool
Howard
Magnificent.
I love the finish on the seat what color milk paint did you use? How did you get that great shine on the seat?
Howard
Re: 3 legged stool
Re: 3 legged stool
Bill White
Well darn....
Why don't we have any dimensions and building/fin ishing tips? Secret???
That's a super project, and I'd like to build one too.
Bill
Re: 3 legged stool
Re: 3 legged stool
Jason Waters
Nice work! Beautiful maple.
Re: 3 legged stool
Re: 3 legged stool -instructions *LONG*
dick gerard
The dimensions are:
Seat started as 2.5 inch x 12 inches. final dimensions are closer to 2.25 x 11.75 inches.
Legs are made from 2 x 2 18.
I started by turning the bottom of the seat. I held the wood in a 4 jaw chuck on a glue block. After the bottom was turned and sanded, i made a small pencil mark at dead center, and I used the pencil to mark the circle upon which the legs would land ... about 2 inches back from the edge.
Then, I removed the seat from the chuck. I then tilted the drill press table to 13 degrees.
Using a compass, I held the pencil end on the center mark previously made and used the pointed metal end to make a pivot point on the circle. The space is the radius from the center to the circle previously drawn. Npw, with the compass metal leg in the mark, swing the pencil end across the circle, both left and right. Move the metal point to one of the new intersections and draw 2 new marks, left and right. Work your way around the circle until you have 6 "X"s on the circle. Now, circle every other "X". These 3 are where you will drill for the mortises. I like to make the mortises first and then turn the tenons on the legs to a tight fit.
I then positioned the blank on the drill press table with the circled "X" and its mate (directly across on the circle, forming a straight line with the point of the Forstner bit (1 inch diameter). I clamped the blank to the table and gently drilled the first mortise. I stopped often to check the depth of the mortise (1 1/4 inches deep).
I then unclamped the blank and rotated it to the next circled "X", lined it up and repeated the drilling. And of course then I drilled the 3rd hole.
I then returned the seat blank to the lathe, this time I held the bottom against a vacuum chuck and pinned the top with the tailstock with a piece of scrap wood (about the size of a nickle) protecting the tailcenter point.
After the blank was properly centered, I began turning off the glue block and finish turned the rest of the top. After all the turning and sanding was complete, I removed the small wooden disk and finished up underneath that guarded area.
Now it is time to turn the legs. Between centers of course. After rounding it up with the SRG, I concentrated on turning the tenon, testing often. When the fit was just right, (requiring a mallet to ease the tenon into the mortise) I knew the fit was adequate.
The next step was to turn the leg itself. For this I had already sketched a form. Since I definietly wanted this stool to say "handmade" I deliberately allowed small differences to creep in to each leg form. And no, I did not get too finicky about the bottoms of the feet since those would be in contact with concrete.
Another scrap wood piece, about 8 inches square and 2 inches thick was drilled with straight holes to accept the tenons. This is my finishing stand. I held the leg by the tenon and wiped on thin thin thin coats of wipe on polyurethane, then placed the tenon in the socket to dry. When dry, I used sandpaper (same grit as final on the lathe sanding) to lighly scuff the leg, then another thin coat of WOP. I repeated this process until the legs were smooth and of the shine I wanted.
for the seat, I had turned 3 stubby legs with tenons not quite as tight as the legs. These would serve to hold the seat as I applied milk paint (3 coats) to the top of the seat. Between the first and second and second and third coats, I used bronze wool to further smoothe the finish. Then, after thoroughly dry, I placed the seat, top side down on a softly padded surface so that I could work on the bottom. I tore paper toweling into strip, rolled them up into tight balls and stuffed them into the tenons to make sure no paint entered the mortise. I then finished the bottom same as the top.
When all was dry, I set about gluing the legs in place. First, I masked off the area immediately around the tenon, and on the legs, masked off below the tenons. You don't want to get ANY glue on those nicely finished surfaces.
I mixed up a batch of West System 3 epoxy and using an acid brush, i coated the sides of the mortise and the bottom. I then applied a light coat to the tenons. I slid the tenons into place and promptly removed them, checking for excess squeeze out. I removed squeeze out with a disposable rag dipped in acetone. Repeat the insertion of the tenon and check again for squeeze out. Remove any (and there really should not be any now). repeat until there is no squeeze out. Remove tape from around the mortise (leave the masking of the legs alone). Place the leg in the mortise for the final time. When all three legs are in, turn the stool rightside up, pad the top well, and place a heavy weight (about 15-20 lbs. should do) on the top. Let dry undisturbed overnight.
That's all there is to it! Easy, huh? Took me 30 years to figure all this out ...
Re: 3 legged stool
Re: 3 legged stool
dick gerard
I used Gallaghers Old fashioed Milk Paint - Barn Red. Before I mixed the powder with water, I rfan the powder through an old flour sifter to locate clumps. The clumps went into a coffee-spice grinder reserved for the shop. Then what remains was also sifted.
After sifting, I mixed the paint according to directions. I stirred well, let it set for about 10 minutes, then drained it through one of those sieves with a handle on it. This helps remove the lumps. You don't want lumpy milk paint.
Then I applied a thin coat with a disposable sponge brush. Let dry, bronze wool (as fine as possible) another coat ... repeat until you are happy. Just be sure to let the paint coats dry thoroughly!
When dry, you can top coat milk paint with just about anything you want. If you want a shiny glossy finish, try wipe on poly. I just use the bronze wool and,, if I want more sheen, I might rub it vigoursly with a brown paper bag held flat like sandpaper.
Re: 3 legged stool
Ditto
Re: 3 legged stool
Excellent report, Dick
Your description is crystal clear and complete. Thanks very much for posting it.
My only concern, and it's not as much a concern as an observation, is that my eye is used to seeing stretchers between the legs of stools. I understand that there is a rich heritage of stools and benches with no stretchers, and, from your description, a 1" maple tenon into 2" thick maple at 13º should be plenty strong enough to resist splaying out, especially in a stool this height and under the weight of your average grandma. But I was wondering about your decision path to the legs-only approach?
This opens up the whole topic of engineering and safety factors. I might have to start another thread on that...
Thanks again, Dick. Beautiful job.
Re: 3 legged stool
Re: Excellent report, Dick
dick gerard
Stretchers are complicated and stretch my brain too much ... ouch! need a beer ... need another beer ... maybe I'll have to try stretchers ... we'll see what happens. By the way, this 18 inch high stool w/o stretchers holds my overly large body just fine. We'll see what happens when I do my next one at 24 inches! Wheeeeeeeee Wheeeeee Whhheeeeee!!!!!!!!!!!!
