Structural Consult
OK, Here's the scene. Making a fixed-rail crib that must be taken apart as far as the sides, ends, and bed board go. This drawing is the of the bottom 4" rail which will be made from full 1" stock and the leg which is 2" by 3-1/2". ![]()
The rails will be set into the legs with 3/4"x3/4" tenons and held by means of a through-bolt into a dowel nut that is drilled in from the under edge of the rail. Both bolt and nut are 1/4x20. The MT will be tight fitting.
And the question is . . .
1 bolt or 2?
My tendency is to use 2 bolts even though the bed board will also be through-bolted in for additional strength.
What say ye-all?
PS: Sorry, but you have to click on the adobe symbol to see the drawing.
