Update on refinishing plywood doors
Wayland
A few weeks ago, I posted questions about refinishing ash plywood doors and drawer fronts in kitchen cabinets. I was having problems sanding through the veneer. Thanks to all for the advice you gave me; here's what I experienced in response.
I tried Citrustrip and it worked well, but, like all strippers, it's time consuming, expensive, and requires contact with chemicals. In using it, I only apply one coat, but I do "stir" it, i.e., at some point in the soaking process, I scrape with a drywall knife, flip over the sludge, and try to smear it out evenly again for contact of fresh stripper with the wood. That seems to work fairly well. After about a day I scrape off the stripper with the drywall knife. Then I rinse with very hot water and scrub with a brush. I then scrape with a carbide scraper, which takes off the half-soft varnish next to the wood that didn't see a lot of the stripper. I then dry the work for several hours and sand with a ROS with 100 grit stearate at slow speed (4 out of 6 on my Bosch). By being very careful, I can avoid sanding through.
Alternatively, I've tried just sanding with 100 grit stearate (again ROS set to 4/6) without using the stripper at all. This works, but takes patience, since the full thickness of varnish tends to resist sanding, but, once you get through it, you can go through the veneer real easily, even with 100 grit. But if you watch carefully and don't get impatient, it works, and works better than stripper. It's also less expensive and involves less chemical exposure.
In either case, I follow up the 100 with 150 and then 220. I then use two coats of Varathane water-based floor finish followed by 220 grit and two more coats of Varathane. Hey, they're cabinets not furniture.
BTW, the edges have 1/8" glued-on solid ash. I run them over the jointer set at 0.020" a couple of times until the stain and food particles disappear.
Ciao
Wayland
