Have a question? Ask Woody!
jointer basics
jointer basics
jointer basics
darrin hill
so now it's time to learn how to use a jointer..
i have one i got a year ago and have not had much use for it..
but now i do and i don't think it;s set right..
do the infeed and out feed tables need to be parallel? cause if i change the infeed to whatever i want to cut, it lowers the infeed that increment. but then when i feed the board it cuts off a 1/16th, but the other side is 1/16th off,so when i get to the middle of the board, it falls that much and the back board doesn't get cut... so i get weird results..
Re: jointer basics
youtube
Jerry Gibbs
check youtube for tuning a jointer. the infeed and outfeed tables need to be parallel. one thing that may not be obvious is that the blades cannot be higher than the outfeed table.
Re: jointer basics
Re: jointer basics
J Barrett Irby
The two tables need to be parallel and when the cut is set to "zero" they should be co-planar or in the same plane. The out feed table should be set almost exactly even with the top of the blades and locked in that position for most work. I set my knives to a known height so that they are all exactly the same and parallel to each other and then adjust the out feed table with a steel rule. I set the ruler on edge on the out feed table and turn the cutter head by hand until a blade touches the ruler. (Unplug the jointer) Adjust the table until the blade just barley "snicks" the knife. Check each blade to be sure that both the left and right ends of each knife snick the same. You may have to tune the setup to get this to happen.
Then I joint a piece of hardwood. I want the outfeed table to exactly support the piece when it comes off the knives. If the table is too high, the pice will bump into the lead end of the table. If it is too low, the piece will be tapered and will drop off the infeed table and create snipe on the end of the work piece. The two tables should move independently of each other and if you change the depth of cut it should not change the height of the outfeed table.
The reason you can change the height of the outfeed table is so you can make other types of cuts and so that you can set the table to the knives rather than setting the knives to the table.
Re: jointer basics
Darin, You probably already know, but
Keith Newton
If the tool is set up perfectly, and you run it with the crown down, you will get this results. Sight down each board, and run the crown up.
Re: jointer basics
Re: jointer basics
The only time the tables are parallel is when you set up your table to the blades - at that time the infeed and outfeed tables and the blades are all at the exact same height. For normal work you never move the outfeed table after that. When you lower the infeed table a 1/16" and feed a board through the cutter the cut surface should be just touching the outfeed table. After you feed enough board to do it, you transfer all pressure on the board to the portion on the outfeed table and "pull" it across the cutter - don't press down real hard, just hard enough to control the board. You should always use push blocks (I use Grr-rippers) to control the board - never your bare hands. 1/16" is just about my normal aggressive cut - I usually cut less when finishing a board. Once one surface is flat, you can hold that surface against the fence and feed the edge through making it straight and 90 deg. to the first surface. Then you can plane the second flat side parallel to the first and using your saw, make the second edge parallel to the first edge. Sorry if I repeated things you already know, I don't know what your skill level is at this time.
Re: jointer basics
Re: jointer basics
darrin hill
turns out the outboard was way off... i didn't know it would be a factor... i tend to think things u buy from a store stay perfect until you buy a new one.. oh well...
Re: jointer basics
Re: jointer basics
Jason Waters
My jointer frustrated me when I first got it, then I spent about 2-3 hours tuning it up using instructions in one of the magazines, and it was a dream, when following proper technique of course.
Out of the box, mine needed outfeed adjustment, knife adjustment, and the infeed table made parallel to the outfeed. Just about everything. Oh, and the fence needed to be squared to the table of course.
So take time to set it up, and your life will be better. Try jointing scrap (2x4's can be fun) until you have the hang of it.
