OT - Cleaning up peanut oil
Tim Caley
While frying the Thanksgiving turkey in peanut oil, I spilled some on the concrete patio. It hasn't been nice enough weather on the weekend's to worry about it till now. Any suggestions on how to remove peanut oil from concrete?
Re: OT - Cleaning up peanut oil
Nat Robison
Try Tide laundry soap, that's what the crews who clean up wrecks on NASCAR tracks use. There's probably some sponsorship deal involved but you might give it a shot.....I doubt they'd use it if it didn't work. I've never tried it but it's probably a cheap place to start.
TIDE sounds like a good idea
Howard In Toronto
I think that sounds like a good idea but if TIDE doesn't work, try TSP. It seems to clean everything the new stuff can't get.
Tom Dunlap
Thin layer of concrete powder, use it like floor dry. Cover w/plastic sheeting. Wash off in a few days.
Dawn dishsoap
Powdered laundry soap...apply like above
Replace patio with a new one...:)
Engine degreaser??
Can't find TSP ...
Mike Farinella
anymore. The phosphates are bad for the environment.
Part of the problem, of course, is that the oil soaks into the porous concrete. I change my car oil in the driveway because I don't have a garage, and have now and again spilled some. I've found mineral spirits, scrubbed with a toothbrush or similar until it's black, brings the oil in the top level of the concrete up to the surface. I then soak it up with kitty litter - the cheapest kind (the clumping kind, while great for litterboxes, is not so good for this cleanup). You can still see a faint residue of oil, but it's far enough below the surface not to be an issue.
Kneale Brownson
Cat Litter or Oil Dry
Kneale Brownson
Cat litter or Oil Dry.
Grind it into the spots with your shoe. It'll take up the oil and spots will disappear.
Re: Can't find TSP ...
john Veerkamp
Tri-Sodium-Phosphate is still available. Some paint stores, Ace hardware, and firms that specialize in fire clean-up usually carry it. There is a substitute for true TSP also called TSP but actually something else.
Thanks everyone.
