seeking different planer advice..
darrin hill
saw the earlier thread but i got a different question...
i have a 16 inch jet planner i got off craigslist..
haunt used it much, but i now have a major use for it. I am making a bunch of kitchen cutting boards out of maple and walnut... the walnut is very rough cut..
how much on average should u take off at a time? i made the mistake of cutting the boards into 18 inch lengths and will have to feed them in one at a time instead of the whole board that i should have done..
but i don't know if i should be doing 1/32, 1/16th, etc..
cause the smaller the number, the longer it's gonna take... and i noticed when running a board through my thickness wheel doesn't stay in place... so if i feed in a piece it will slightly raise the cutter as it spins.... not spin.. just won't stay locked in place..
Re: seeking different planer advice..
NickinMass
It depends a bit on how much you need to take it down and also the design of your planer. My general approach is to joint one face and edge, then plane with pretty deep cuts (up to 1/8", if your planer will handle that deep) until I've got a clean face, then take mid-thickness cuts, alternating sides until I'm close, then a final light pass on both sides to the final thickness. The depth of that final last pass will depend on whether you have corrugated feed rollers and if you do, how deep a cut you need to take to get rid of the feed roller marks.
john Veerkamp
I presume that you will be planing this side grain. I routinely do 1/16 on dry walnut. I also try to reverse the lead edge between passes. You might try a smaller increment the first pass or so. Can you lock the height with a vise grip to keep it from loosening?
darrin hill
whenever i try to do a deeper pass it slowes way down and gets really loud..
didn't know if it was too much for it to handle..
Bob Lang
Sounds like the knives are dull. Taking 1/16" should not cause the problems you are experiencing.
Bob Lang
del schisler
That shouldn't make any difference how much you take off. If the board is good and flat. Now as far as the change in depth of cut if the planer get's louder the knives probly dull. Make sure that they are installed right?? Once i got mine installed backward it still cut very bad. so check that. Make a jig and what i do is take 1000 grit sand paper and go over the cutting edge a few time's and this may get you by for a while but they need to be sharpen by a good knife sharpen service. Just watch they will still cut meat !
darrin hill
so what can a knife sharpener do that i can't? i have diamond hones and stuff like that for sharpening turning tools..
del schisler
i guess you can do that. I didn't know that you had all those. Sharpen the knives and you should be ok. I do mine also . I didn't mean you couldn't do it sorry if you thought that way bye
Re: I wouldn't recommend sharpening planer
knives by hand unless it is just a quick touch up. You have a 16" planer,
a variation of a couple of thousands (.002") will mean only part of your knives are actually cutting properly. You asked what a sharpening service has that you don't - Normally they use a water cooled surface grinder to sharpen planer blades. I have a small one in my shop - a 6" X 12" Boyer Schultz. The sharpener services will have a larger one and surface grinders are capable of sharpening all of the entire blade length to within .0001" or .0002" in thickness (that's tenths of a thousandths), and all blades the same thickness. Not saying you can't sharpen yours - but the planer will do a much better job if all the blades are set to and cutting the same. I know I am not capable of sharpening by hand to anywhere near the tolerance of a surface grinder - and I don't know of any toolmaker or machinist that can.
darrin hill
i confuse easily... i don't have the $ to replace the blades... and my idea of a knife sharpener is a guy who does what i do...
someone has a post in this thread about knife sharpeners having this space age machine that does it all ..
but as far as i know, the local knife sharpeners use big honing blocks... thats as fancy as we get in texas...
Guess the terminology may be confusing, the reference to knife sharpeners was meant to be describing a shop that sharpens woodworking tooling. Usually they sharpen circular saw blades and often have the equipment to sharpen Planer and joiner blades as well, many sharpen carbide shaper and router bits. Normally this is not expensive. I would expect there to be one in just about every medium size city in USA. They are used by furniture builders, sawmills, and just about every industry that works wood. If you can't find one locally there are many that you can send your knives to and have them sharpened. Just post a message and ask if any are in your area or who you could send them to and I'm sure many will respond.
