phase converter
phase converter
phase converter
Dan Long
Hi hope I explain this right. I have a 15hp. idler for my phase converter which runs great, Most of my stuff is 5hp 3 phase and they all run great. Recently have restored a beach drum sandewr which has a 7.5 hp on one drum and 5hp. on the second drum it also has a 3hp for the feed all of which are 3phase. My question is should I hook these up in series or parallel .
Thanks Dan
Re: phase converter
Re: phase converter
del schisler
go here and read some can be all way's of hook up . http://www.google.com/#hl=en&sa=X&ei=jKdcT5vRKuPr0gHOh8i0Dw&ved=0CBkQvwUoAQ&q=3+phase+series+or+parallel&spell=1&bav=on.2,or.r_gc.r_pw.r_qf.,cf.osb&fp=297cffb4fb1be379&biw=978&bih=561
Re: phase converter
Re: phase converter
John in NM
Parallel. You don't want all the current required to run 10.5 hp through the 3 hp motor. Almost everything done in house or shop wiring is parallel.
Re: phase converter
Re: phase converter
Dan Long
Thanks parallel is the way i will do it . Dan
