Wood Chips
Wood Chips
Wood Chips
Kelly M. Robison
Hi Everyone, I really want to thank everyone that has replied back to me on my other problems. Now I have a new one; I have a big 20" planer that I use to re-face my lumber. I have found that I can buy unfinished lumber cheaper so I like to plane it myself. I want to hook it up to a "collector" so I can collect the chips as they are coming out of the machine. My problem; I have a 2 HP dust collector and I have tried using it, but it gets clogged up real fast. What kind of a collector can I use that will gets these chips as they are being discharged??? My collector works great on my other machines but can't handle the big planer. I usually just let all the chips just go on the floor then sweep them up and get them with a dust pan but I am looking for a "better mouse trap". Thanks,
Kelly in Port Orchard
Re: Wood Chips
Re: Wood Chips
Charlie Lenz
How about a picture of your planer, and how your ducting it to the DC. A 2 hp DC should be able to handle it.
Re: Wood Chips
Re: Wood Chips
NickinMass
I'm with Charlie - what does your ducting look like and what kind of 2hp DC do you have? I believe a 20" planer needs 800 CFM, so if you have a lot of flex and/or elbows between the machine and the collector, or undersized ducting, you might not be getting enough CFM at the machine. Also, are you using a 4" port?
Re: Wood Chips
Re: Wood Chips
Joseph Mulherin
Kelley, I would suggest you hookup the planer to a garbage can to collect the chips. The DC would also hookup to the can to provide the suction. The small chips and sawdust would go to the DC but the heavier chips would be collected in the can and not harm the impeller of the DC.
Re: Wood Chips
Re: Wood Chips
What Joseph said.
A 2 hp bagger or canister DC should have enough CFM to handle the 20" planer.
If you are filling up your container very quickly, run a hose to a Thein separator of a trash can separator and then to the DC.
Re: Wood Chips
In agreement except.....
Dick Coers
with some exceptions. Poplar can really let go of some really long chips. I've seen curls that are 6" tp 8" long. Hard maple, really small. How much flex hose do you have? A foot of flex is like 10' of steel duct.
Re: Wood Chips
Lee Valley solution
Cecil Nickerson
Get yourself a 55 gal or 45 gal paper barrel (used to be called china barrels by moving companies). Mine come from a company that repackages cleaning products. Get one of Lee Valley's cyclone lids (I notice they now offer a smaller size which will fit a garbage can) and you will have created a cyclone collector which works flawlessly. My setup keeps up with a Hitachi F1000 with no problem and has been doing so for a number of years.
Re: Wood Chips
Re: Wood Chips
Keith Newton
Kelly, Sometimes, the problem is just not getting enough air through the planer to move the chips up the system to carry them away, regardless of the size of pipe or power of the blower.
I had that on my 24" planer, with a 7.5 hp Phelps blower, with plenty of return on the back end. I ended up boring 3 2" holes in my hood above where they are ejected from the planer, which added enough air flow to carry them up the 10' before it turned to head toward the blower.
Figure up how many square inches in your blow pipe, then make sure you have that many square inches of intake between the bed and rollers when you are feeding wide stock, or multiple boards. If you have a constriction on the intake, you shouldn't expect full flow through the rest of the system.
Even on my little 12 portable planer, which I have ducted to the side, I found an improvement when I cut a big opening on the opposite side from the duct. Inertia will carry the chips into the hood, but FREE-FLOW takes them away.
With a 2 hp blower, I don't guess I need to tell you to keep all the other ports closed.
