OT - painting my house exterior
Howard In Toronto
I'm looking at painting the exterior of the house this spring. It's two stories, and mostly exterior stucco with a fair bit of wood trim.
Am I revealing how much I've lost my mind if I contemplate painting it myself?
If I do, does renting a sprayer at HD make sense? I'm thinking speed and consistency here.
As always, your opinions and direct experience are mighty appreciated.
Thank you.
Howard
Re: OT - painting my house exterior
William A. Roland
William A. Roland
That is way too much for me and I would not attempt to do a job that big. If you have scaffolding to put up you might be able to do this. On the sprayer, they do have overspray and you would have to mask the parts you don't want to get oversprayed.
Jason Roehl in Lafayette, IN
I'm not inclined at the moment to go into an exterior painting dissertation, but keep in mind that exterior spraying on most surfaces requires back-brushing or back-rolling to work the paint into the substrate. Add that to masking, scaffold, ladders and the like, and you may not be time ahead with spraying. For me, I've got a lot of experience spraying, and I wouldn't hesitate on what you described, but I also have a lot of experience masking, so am fairly quick at it.
Sometimes it's quicker to not spray, but experience is really the only teacher on that judgment call.
Jason (over 15 years in the biz)
If you're going to do it yourself, shop around for rental scaffolding (locally, we have a specialty scaffolding-only rental place that's much, much cheaper than the general rental yards, and more knowledgeable too), and, after you think about how long it will take you to do it, pencil out the rental cost; then price purchasing scaffolding.
Having done some painting with scaffolding and with a ladder, I would never do a whole house from a ladder; scaffolding increases speed, efficiency, and safety beyond describing.
In addition to what the others have said - prep work is everything. Do the prep work (caulking, masking, etc.).
I rented an airless sprayer a number of years ago and sprayed several buildings at the riding club where I used to belong. I was able to complete all the painting in a day. The prep work took several days.
Working by yourself on a two story house? Expect something similar.
Another thing to consider - renting a boom lift. They are a lot easier than scaffolding.
John McGaw
My advice is, if your terrain and landscaping will permit it, rent yourself a man lift instead of scaffolding. It is far faster and safer. My boss in Alaska used to stain the exterior of his home every few years and he was in far-from-good physical condition (heart attack, overweight, bad back, 55+ years old) and he managed it pretty easily using a sprayer and lift. The gable ends on the house were, at a guess, 30-feet high and getting up there with ladders and scaffolds could have been, literally, a killer.
Bill Howatt
I did the top story of a wood-sided 2 story house. I rented 3 sections of standard steel scaffolding to assemble and disassemble to go around the house. I was doing the job by myself.
I found that putting up 2 sections was fine but adding the third by myself was very difficult. I then elected to go with 2 sections and use a step-ladder on top of the 2 scaffold sections to reach the soffit which was only 21 feet off the ground. I didn't really like doing the soffits. I spent a lot of time moving scaffold, wheels didn't work in my terrain.
If I had to do it again I would not go the scaffold route, at least not the standard scaffolding I rented. A man-lift sounds like a better idea. My current house has high areas outside and I find applying stain from a ladder not too bad.
As always, for a good job, it's the prep that takes the time.
Good luck and by all means be safe a fall can drastically change or terminate your life.
Bill
