THE WOODRAT IS BACK!
Mini-sled . . .
Mini-sled . . .
Mini-sled . . .
steve mackay
Been trying to beef-up the goose-neck on my semi-trailer Pershing missile launchers. But the word is consistancy. I've watched all the different flavors of TS sleds here on WC. Why not shrink things down a bit ?
I've got a 22.5 degree block for the 45 degree rake and a 45 block just in case. The end blocks bridge the base so that the width of the cut shouldn't matter. I'm pondering some type of clamp but still working on it.
Now instead of only a butt joint we've got two spline joints also. After butt jointing the forward platform we'll just flip it over and repeat the process.
WC is like watching Ol' Norm . . . you may not use ideas "as is" but the technique can be adapted.
Re: Mini-sled . . .
Nice !
Don Orr
What a great idea to make your joint much stronger. Great job. By the way, I really enjoy all "toys" that you make and post.
Re: Mini-sled . . .
A Sled Note
I've made and use a bunch of TS sleds to make such cuts. I don't, however, use the fence as a guide for the cut for 2 reasons. 1 - My fence is not set precisely parallel to the blade; it "opens" by several thousands at the rear to help prevent entrapment on the cut-piece. 2 - The cutting action of the blade can, on occasion, tend to pull the work away from the fence slightly requiring the operator to exert lateral pressure to maintain contact with the fence.
The Alternative:
I use 3/8x3/4 strips of HDPE as runners in both miter slots and fix them to the sled platform so that it spans the blade. This eliminates any lateral movement during the cut. I then fix to the platform whatever holding structure I need to control the workpiece after making a preliminary cut part way through the platform. That cut line then makes it easy to register the holding structure at a true 90 or any other angle for the desired cut. The operator can then concentrate on using straight-line movement to control the cut.
In my view, this is a safer way to do precise cuts with greater control.
