inlay assistance needed...
McKay
I am teaching myself to do string inlay. I have the video with Steve Latta and I also have the tools to do the inlay. The inlay of the strings has gone pretty well and I am satisfied with my first attempt. However, I do not care for the traditional berries so I want to put leaves on the end of the string inlay. I have done a fair amount of marquetry so I had some green veneer. hummm..Not thick enough for inlay. So I glued two of the pieces together and got a good thickness but upon planing and scraping, I discover that the green does not go through the entire thickness of the veneer. (Paul Schurch veneer). With marquetry you do not remove nearly as much material. Hopefully you can see in the picture the leaf that was inlaid in the walnut is not as green as I would wish. I am hoping to get some feedback as to what to do to make the leaves greener. I have aniline dye put it also does not go deep enough.
What say ye?
Re: inlay assistance needed...
Let it soak
If the dye solution is thin enough, it should eventually permeate the inlay material completely. Lotta variable mileage here, depending on how small the dye components are.
Dick Coers
It's pretty easy these days to get something to pull a slight vacuum as it soaks. Food savers sometimes have a lid to fit on jars (pickle jars) is one example. I think it is better if you pull the vacuum, open the container, and pull the vacuum again. Cycles like that seem to pull the fluid through the wood a little better.
I would cut the opening for the leaf. Seal it so any analine dye won't bleed into the leave void edges. The install the leaf. Use Frisket to make mask and airbrush the analine dye onto the leaf. I haven't tried that exact technique but have done something similar with paint. It doesn't bleed into the endgrain of wood as bad as analine dye does.
Of course you need an airbrush and you have to be pretty exact when you cut out the Frisket mask.
That is sort of right.
Keith Newton
i have a couple of jars like that, and have used them to re-hydrate wood before.
If the wood is floating in a liquid, you can see the air bubbling out of the wood as the vacuum is being drawn. Then when the vac is released, the vacuum inside the cells pulls the liquid in, rather than through. And you are right, it takes a couple of times to totally saturate the wood.
Of course, if this is used on this veneer, it will need to be dry before using.
It might make more sense to try some sort of marker after all the sanding is done, or like John says below.
It has been a while since I have done any marquetry, but I never could bring myself to use any false colors that don't naturally occur. I give the viewers credit for having enough imagination, for their minds to make the color correction, without it having to be actual.
