200+ woodworking book reviews
Hand rail wood "reclamation"
I was gifted with a lot of 6/4 oak hand rail wood. The wood is ~6/4 x 8" x ~10' long. It has some finish on it as well as some surface grime.
I don't have a drum sander. I have a belt sander and a planer.
I was going to use an 80 grit belt and go over it lightly and then use my planer.
Any other suggestions?
TIA.
Re: Hand rail wood "reclamation"
Dave Bair, Eaton Rapids, MI
I never machine after sanding; grit gets into the wood and dulls my planer blades too quickly. You might wash your rail with mineral spirits or wire-brush the surface clean.
Bill Tindall
I am not a fan of machining wood that has been sanded for fear of left behind sanding particles. To remove grit from wood I use a wire brush on an angle grinder and then plane it. The wire brush takes to surface off the wood right down to bare wood.
Wire brush works for me.
Also a lot quieter than the sander.
