CPVC pipe
CPVC pipe
CPVC pipe
TomD
I use this pipe for a variety of stuff, for instance I used it to hold bearings for a spinning wheel I made. That was back before I got all my metal lathes. It can be turned on a wood lathe. I use it for stuff on my wooden boat, I made a Robaza out of it. It's great stuff, but not the best plumbing pipe. With the Ascendancy of PEX, I am finding it harder and harder to get. I was just wondering if anyone knows anything about it and whether industry will completely phase it out along some timeline. Unfortunately I didn't find much googling. It overlaps with some other popular searches.
Re: CPVC pipe
Robaza???
Tom Dunlap
Sorry...I can't help with sourcing the plastic.
What is a Robaza???
Tom
Re: CPVC pipe
Re: CPVC pipe
John in NM
Its still pretty common down here, last time I bought any. Local codes forbid white pvc in habitable structures, but freezes tend not to be bad enough to rule out cpvc as well. At least that's how the plumbing inspector explained it a few years ago.
Re: CPVC pipe
Re: CPVC pipe
John McGaw
It will probably be around for a while. Grainger sells it and it can be found at various online plumbing supply sites. Given the characteristics of CPVC and your possession of a proper metal lathe I'd be inclined to turn bearings and such from UHMW polyethelene instead which is much slipperier and more wear resistant and is unlikely to ever disappear from the market.
Re: CPVC pipe
Re: CPVC pipe
Gary Camp, Bend, Oregon
You might also check with fire sprinkler installers. In our area it is used when sprinkler systems are added to existing buildings.
glc
Re: CPVC pipe
Re: CPVC pipe
TomD
Just on the bearing thing. I needed to mount some cartridge bearings in a piece of wood. The piece was rather oddly shaped, like a peanut, and while I could have location drilled it in a drill press, what I did was take a CPVC connector, and turn the outside on centers so it was cylindrical, then I bored the ends to hold the cartridge bearing to a tight fit (long point of skew). Then I just glued that part into the wood piece. That way the bearings were not in wood, and the CPVC has enough give to it, that it will transition the steel to wood without any problems one might have going direct. CPVC glues very well with epoxy if one preps it either with CPVC glue or hazes it with heat.
Re: CPVC pipe
Re: Robaza???
TomD
Hey, why don't you just google it? Oh... I can't find it either, I must have the wrong name for it too. :(
Re: CPVC pipe
Kneale Brownson
So what is it, what does it do?
