cabinet door problem!!
Rick Snyder
Hi All
I have converted an old chest of drawers into a cabinet with glass doors on top and a drawer at the bottom. The doors are inset to the face frame. Prior to staining/finishing, everything fit perfect!. In the final installation of the doors, the left side has "springback" approx. 1/2 inch. I'm using double touch latches(top and bottom) which once closed, should keep the door flat to the face frame but it's the idea that the right side works just fine and left side doesen't. The left door is square and flat just like the right side door is. WHAT HAPPENED?? and what might be the cure?
Thanks, Rick
