Cutting rectangular holes in door?
The powers that be at the church would like a couple of lights in two doors.
I'm thinking about just doing some plunge cuts with my circular saw. I was going to remove the door and use my long clamp guide. After I do the two long cuts, I was going to use my jig saw or a coping saw to connect the two cuts.
Any other suggestions?
Re: Cutting rectangular holes in door?
John McGaw
What is the construction/style of the doors? If they are panel doors and you are simply removing some panels then a router guided by a template should do a neat job of removing the moulded edge which holds the panels in place allowing glass to be dropped right in. Of course you'd have to come up with some sort of moulding to replace that removed but this shouldn't be much of a problem since the profiles generally used are pretty simple.
If the doors are just slabs then all bets are off and almost anything goes as long as you know how you will be arranging for the lights to be held in place.
paul in AZ
I just cut a square hole, not in a door but some plywood. Four plunge cuts and then a Japanese pull saw to get to the corners. Worked fine.
Jason Waters
John,
I agree, use a router. Plunge cutting with a circular saw would not be my first choice in general.
A couple more thoughts, are these interior or exterior doors? At a church (i.e., commercial building), they all should be solid core or solid panel doors. However, be careful about a hollow core door, that could be a mess. If it's a cheap door, and it's a few lights, it might not be that much to buy a door with a light, and just mortise and fit it. Depends on the situation.
I say more info is needed. Got a pic of the door?
Interior doors, slab construction
The outer "plys" are about 1/8". There appears to be a "frame" within the door.
The lights have have their own trim with screws going from one section to the other. Sort of a split frame construction. They will sandwich the hole.
A "Holy" endeavor
Re: Interior doors, slab construction
NickinMass
It sounds like you have typical slab hollow core doors. All the doors of this type that I have seen strips of corrugated cardboard (on edge) to keep the door skins separated - be careful after you make your cuts that you keep the cardboard strips in place.
Did a 10"x28"
Bill Howatt
I put a light in my door which was the typical molded hardboard slab door with the corrugated cardboard inside.
I layed it out, drilled a hole and and cut the opening with a jig saw. Had to take a chisel and cut out some of the cardboard and hot glue so I could fit in some 1x1-1/8 between the front and back panel. I then cut some pieces to hold the glass and trim the opening.
Bill
John McGaw
In your case it appears as though the edges of the opening will be concealed so almost any method of cutting will do the job and a delicate plunge cut with a circular saw might be as good as anything. Be prepared for a door which becomes quite limp when you make the cuts in both sides. You will really need to glue in suitable framing to re-stiffen the structure and box in the opening. When I did openings for top and bottom vents in a similar door I just ripped some 2X2 pine to the proper thickness and glued and bradded pieces between the skins to gain a bit of strength before screwing the vent grates in place.
Jason Waters
I agree if your overlap is enough on the sandwich type, you can cut with about anything, a lot of people use a jigsaw even. No need for router (I was thinking you would put glass panes in).
Usually, there is some stiffening (cardboard or something) in the middle that you cut out. You can usually tear the two sides off the stiffener, and glue it back into the door to keep it from collapsing from the sandwich action of the window.
Good input from all here.
Not only slab, but "filled" slab...
One door had a poplar core. Let it suffice to say, it wasn't very light. It was a pain getting it down to the lower level to cut it.
The other door was worse. It had a particle board core. It was heavier.
Both doors cut well with the circular saw doing a plunge cut. I used a clamp guide. I then cut into the corners with the jig saw.
Re: Not only slab, but "filled" slab...
John McGaw
So it appears that they may have been fire doors. Did they have UL IDs? Metal frames? If they are (were, actually) fire doors you may have some problems with local authorities since such doors, when they have lights, have special requirements like embedded-mesh panes. I hope that I turn out wrong but it can't hurt to look. Forewarned is forearmed.
I think the church got a "deal" on the doors. All of the doors in the older part are the same type - in a metal frame. The old doors to the former restrooms were of the same construction.
I put lights in the library door and in the door to the priest's office. They don't really need fire doors in those locations. We have fire rated doors in other places in the building.
