How to cut a circular ring
JERRY DRAPER
I need to cut a ring 12" in dia. and 1/2" wide. How can I do that without using a jig saw?
JERRY DRAPER
Re: How to cut a circular ring
NickinMass
Router and a trammel would work (although you'll have an easier time if you can rough cut the outside of the ring). Set the radius for 6", cut the outside, then move the radius to 5.75" less the diameter of your router bit. I'd do the inside cut in a number of passes (do once around with a shallow cut, lower the bit and go around again, repeat as necessary). Of course this assumes you have a router...
Thanks Nick
J. Waters
And usually it's nice and smooth when using a router. I like this method the best, though it can be time consuming.
