Re: Jig ideas help
Alan in Little Washington (NC)
Simple jig- Make a wooden collar to hold the pipe vertical on a router table.
Cut holes for the pipe in two 12" X 12" pieces of 2X12. You can use a jig saw or a bandsaw. Widen the access slot on one board to 1." The holes don't need to be pretty, but they should hold the pipe VERY SNUGGLY. (You'll need a second collar for the pipe fitting.) Use a section of pipe to align the two boards, clamp the boards so the slits close up a little and the collar really grips the pipe. Orient the access slits to different edges and glue/screw the two boards together to make a 3" tall collar.
Rabbet the bottom lip of collar hole so there is enough room for a round-over bit with bearing between the outside of the pipe and the collar.
Install a round-over bit with bearing in your router table and set the height. Round over the edges of the access slot and rabbet.
Push the first piece of pipe into the collar, turn on the router, and push the collar until the bit and bearing contact the pipe. Hold the bearing against the pipe as you move the collar and pipe assembly around the bit. When the outside is rounded lift the assembly over the bit and round over the inside of the pipe.
PVC pipe has relatively thin walls so you should be able to easily round over the inside and outside of an end in less than 30 seconds.
