BLO on coasters?
BLO on coasters?
BLO on coasters?
Pat Evans
The commercial coasters we have are too small for my beer mugs and most of our drink glasses. They are also impervious to water which means when glasses sweat, they sit in a pool of water then drip when you pick them up. I made coasters from squares of carpet tiles which work great, but aren't that attractive.
I've resawn some cedar, walnut, and cherry for my BIL. Not long enough for pieces for furniture, but plenty to turn some wooden coaster. (He has the lathe, not me.)
I don't want a waterproof finish since I want the wood to absorb condensation. I'll put either feet or a waterproof backing on the bottom. Would BLO be a good choice for finish? Are wooden coasters even a viable idea? They might not last for years, but should be simple enough to make that they could be replaced frequently.
Re: BLO on coasters?
Keith Newton
I wouldn't bother with a finish for what you desire. The BLO, will slow absorption a little, but will circle so badly, that it will look worse than no finish at all.
However, none of the woods you mentioned will absorb moisture as fast as a frozen mug can produce it, so you might want to rethink your expectations.
Besides, if they are dry and flat when you make them, they will cup when they become wet, producing a little rocker for your mug.
Maybe a better solution, would be to make little grates, which allow the moisture to just flow through, could cut down on the drips, but lifting and tilting will likely still allow some drops to fall.
Re: A different approach
Ralph Lipeles
Just down the beer fast enough so that you don't have to put the mug down.
Jason Roehl in Lafayette, IN
I agree with Keith on the BLO--I think it would look really bad in very short order.
I have some (commercial) wood coasters that have a round cork insert. The cork works okay, but could be a bit thicker and maybe a more absorbent version. The biggest downside is that the coasters are too small in my opinion. They're 3.75" square (with the corners rounded), and the cork insert is a 3" circle. Most of my glasses fit fine on them, but my coffee mug doesn't--it's a 20 oz. ceramic mug, so it sits on the wood and even overhangs the edges a bit.
Jason
Dale Lenz
Vote: no finish
Dale Lenz
Have some carbon storage modules, about 3.5" square, 1/2" thick, that we gave away at our State fair about 20 years ago. Of course people like the idea but wondered what to do with them beside locking up carbon. Suggested coasters w/o finish, seem to move them. Mine are: Cherry, SYP and oak, flat sawn, have not warped much if any, do recall suggesting to folk to find a quarter sawn modules. Even unfinished, my cold drink still forms a suction to the coaster and falls away from the glass half way to my mouth, can be a pain and could damage the furniture, dings and such. However, do have a full inch of rough sawn catapala that works the best, really sucks up the moisture and don't recall the wet glass "sticking" to the coaster. I put little corner felt pads on the bottom of my wood coasters, huh...carbon storage modules, :).
Bill Tindall
Boiled linseed oil repels water off my gun stock like, well, water off a ducks back.
great respect for catalpa,
Keith Newton
Dale, I started to suggest using some end-grain cuts of something really absorbent, like cypress, or water tupelo root, but didn't think about catalpa. I have a big log laying out back, which has been there since 03, without any end coating, yet it never showed the slightest end checking.
Hardly any sapwood, yet,, it would still send off sprouts whenever it rained for several years after harvesting it. It is truly a shame that it doesn't make a good straight saw-log, it could probably give teak a run for the big money.
Question
John in NM
Maybe it's too early... but what are carbon storage modules?
I would say no as well...
John in NM
The hardware store variety is easy to use and provides an almost varnish like finish in my experience. Products like Tried and True are not as easy to use but seem quite water (not moisture) resistant. Neither is what you're looking for really.
I'd have to suggest just raw wood. The idea is that the wood soaks up the drips and then lets the moisture evaporate rather than seep out onto your table top. I tend to view coasters as I do cutting boards - disposable after a few years. I have lots of 4/4 scrap for making them, and they take abuse.
I remember my dad "inventing" a better coaster years ago. It was unglazed ceramic (with glazed decoration) and really worked very well. He had wanted to sell them, but pre-internet these things were much harder to do (not that it's all that easy now either :D )
Howard Acheson
Even un-finished wood will not absorb the amount of moisture that comes off a beer mug.
Thanks guys
Pat Evans
My favorite suggestion is to drink the beer faster. Might not be as good an idea for some of the other concoctions we drink.
Unfinished sounds like the best approach.
I'm familiar with coasters sticking to the bottom of a glass. I would like to have these turned with an asymetric pattern on the glass bearing surface, but still have a lip around the edge just in case water isn't absorbed quick enough. Now I just have to figure how to make that pattern.
pattern
Bill Tindall
Use a chatter tool. It will make an attractive pattern for the task at hand.
BIL will get a chatter tool for his birthday
Dale Lenz
Re: Question
Dale Lenz
John,
Any piece of wood stores carbon until the wood is broken down. So...we had 1000's of 3.5" x3.5" x 1/2" wood squares with the following on the squares, aka carbon storage modules: The carbon trapped here will never escape into the atmosphere and cause global warming as long as YOU don't let this carbon storage module burn or rot! Circa 1990.
It is an educational message. I could go further and talk about a certain person, but won't go there, :).
And here I was....
John in NM
Imagining a little box with a charcoal briquette in it :D :D :D
