Speaking of contractor's saws...
The playhouse was gifted with a Delta Model 10 Contractor's saw.
Unfortunately it really belonged to a contractor. It is quite used, rusty and all that.
Most of it I can deal with. The blade elevation is quite stiff though. I have been cleaning it. Any suggestions as to how I can loosen it up? It is really a two handed operation to raise and lower the blade.
TIA
Re: Speaking of contractor's saws...
Jason Waters
It probably needs taking apart, like the table top removed, a good cleaning, and some grease. You'll probably need some help, and a good mechanical skill, as you will need to re-align the miter slots, etc. possibly depending on how far you take it apart.
I have to do this every other year or so
Bruce, a MN Galoot
and all it really needs is a good cleaning, as Jason said. Scrape all the crud out, wire brush the ways and gears and use a good dry lubricant on the gears and slots. You'll be pleased at how easily it works. If it's like a lot of job-site saws, it probably hasn't gotten much care over the years.
Cleaned and lubed, still have problems
The blade tilt is working fine now. The blade elevation mechanism is still really tough to turn. I got a lot of pitch and sawdust off of the mechanisms.
Re: Cleaned and lubed, still have problems
Carol
Threaded rod slightly bent?
Re: Or - 2...
Gary Bindel
You might need to pull the shaft out and clean the bearings. I've had it where a buildup of crud(technical term?) forms that makes it hard to turn.
I'll try that
try this also
del schisler
also is their a nut to tighten on the outside to keep the blade from lowering when sawing ?? Mine does and here is what i had to do check the end play with the nut and shaft that when you tighen it down and loosen it their is just a little play in it. If it is to tight to start with it will be tight when it is sopose to be loose ? Just a thought . It take a little playing around to adjust it.
Charlie Lenz
You may also want to check where the cast arbor assembly pivots. There is a fairly large pin where it pivots that may be gummed up or rusted. Removing the pin is a fairly simple task. First remove the throat plate, remove the blade, lower the arbor and you should see a set screw above where the assembly rotates. Loosen the set screw and pull the pin, you may have to tilt the assembly to pull the pin, I can't remember. Another thing to check is the gear lashes, how the gears mate with eachother. There is a way to adjust the lash, the bushing inside is ecentric. An Owners Manual describes the procedure with pictures.
