Tilting the drill press table
John in NM
Took some pictures of this yesterday, it's the easiest way I've found to get a really long hole plumb so that you can hit the center of another hole drilled from the other end.
After the operation is done, its really not too hard to re-level the table.
Mine needs a little shimming to get it right front to back, so I have to remember to put the shim back in before checking the side to side and locking it all down. I like the little back plunger dial indicator for this kind of stuff, but really any dial indicator will work.
Re: Tilting the drill press table
Re: Good tip John
Even without a dial indicator, bending a piece of rod into a sort of S-curve will work (Egyptian in general shape - kind of squared-off corners, though the more critical issue is that the two ends should be more or less parallel to each other) - you clamp one end of the rod in the chuck, and the other end should describe a circle around the table. When the rod is just scratching the table in its full circle, the table's "flat" to the chuck.
I'm sorry about all the divots that I assume some past owner (surely not you) added to that table. Over on the Old Woodworking Machines site, this is known as the "arc of shame."
You guessed right alright
John in NM
This drill press came out of a school shop in Texas. I sometimes fantasize about replacing the table, but it would cost a couple hundred and the divots usually don't cause any problems, so my cheap gene takes over.
steve mackay
I've made my DP do a LOT of gags and I NEVER thought of this one ! It'll be a valuable addition to my arsenal ! Thank you !
Thank Mom
John in NM
She gave me an old book about drill presses as a joke, thinking I knew it all already. Funny thing is, even though I knew the table tilted for obvious reasons, I never thought of apply some of my regular tasks to the drill press until I actually saw a picture of it being done :D The mind can be very strange.
Whats the book ?
Re: Whats the book ?
John in NM
"Getting the Most Out of Your Drill Press"
Published by Delta/Rockwell in 1952, originally 1937
A lot of it is pretty basic stuff, but there are several good ideas in there too. Well worth picking up a copy if you find it cheap (mom's jokes rarely cost more than a buck or two :D )
Re: The book *LINK*
Bob Entwisle in NJ
Here is a link to a PDf of the 1947 version of the book.
Bob in NJ
http://vintagemachinery.org/pubs/detail.aspx?id=2862
Re: You guessed right alright
Jason Waters
I admit to having a few "dots" of shame, that I did myself. It wasn't intentional, I assure you.....Most were drilling through the plywood backer, and not realizing the center got off when I cranked up and down.
But that is pretty bad.
Cool, thanks Bob
Re: Tilting the drill press table ( suggestion )
Charlie Lenz
With a benchtop style Drill Press you can use the base as the support for the material being drilled as you show it. For a floor standing style drill press I'd like to suggest bolting a piece of angle iron horizontally to the table to support the material being drilled.
Bob Lang
Back in the day, Delta published one of those for most of their machines. Handy references when you need them.
Bob Lang
