Re: OT: Old Gasoline
TomD
I don't pretend to know anything about this, but had to research it recently after seeing something about it on a ATOH episode. Two new problems came up. Gas is a lot less long lived, 6 weeks max, which frankly doesn't correspond with what I have experienced. Second the stuff with ethanol in it collects water, so if you have been cycling gas through a can there will tend to be water build up down there. Gas stabilizer helps, but there are two kinds, I think red and blue, and only the blue will help with the water/ethanol problems. I don't know how that tracks across the country, but at the very least i am now going to be trying to source the ethanol free stuff for my small engines, and I will be reading the labels more carefully when buying stabilizer.
http://video.pbs.org/video/2190819128
Fuel starts around 20 minute mark.
Funny part is that my local province has a FAQ on gas, lots of happy happy. Then when it comes to aircraft, they just flatly say do not use the ethanol stuff. Aircraft operating environment is a lot different. And I hear this carries over for craft that use 2 cycle engines, where some truly odd things happen in the air that do not happen on ground, but it still made me think that it sounded a little fishy.
