Re: OT - Tiles on a Garage Floor
Ric Taylor
Thanks for the various replies.
I don't mean to be argumentative, but just to show the other sides of the coins that you have offered in your messages:
The hardness of the concrete under my feet is not a problem. My shop has been on that concrete floor for 10 years. I wear Crocs and stand on a rubber matt. Even after being out there all day, my feet are good.
I have previously considered painting the floor and having an epoxy surface applied. I discarded those ideas because I have seen them in place in other shops. They do look good, but the heavy vibrating feet of heavy tools such as a lathe eventually work their way through both of those surfaces, revealing the concrete. Even commercially-applied epoxy systems, which I have learned are about 10 times stronger than the DIY brands, will not stand up to that punishment over time.
The snap-together tiles look great, but I'm concerned about moisture getting underneath them and causing a mold problem. I also doubt if that surface is firm enough for my lathe. It is important for the lathe movement/vibration to transfer to the concrete. Wood won't work because the car will still be parked in there, and that causes other moisture problems.
Sealing grout around tiles is not a problem. I have learned that porcelain would be better because if it became chipped, it is colored all the way through, whereas ceramic is colored only on the surface. The information about tiles with a gritty surface to reduce slickness is appreciated.
So, I'm still back to my original question about what surface prep or cleaning might be needed, if any, on the concrete to insure there are no adhesion issues with the thinset. The floor is level, so no problems there, and I will look into the suggestion about roughing the surface.
Many thanks, other thoughts will still be appreciated.
Ric
