Spray painting
Spray painting
Spray painting
james runchey
I've got 14 antique exterior shutters I want to paint. I plan on priming with an oil base, and finish coating with latex. I'm thinking of spraying, which I've never done before. At the present time we're in a motel in Houston, which just happens to be right across the street from Harbor Freight. They have a hvlp at a reasonable price. Would this be suitable?
Re: Spray painting
Re: Spray painting
Dick Coers
Only if you thin the paint a bunch. I would suggest you rent an airless. About the same money for a 1/2 day rental.
Re: Spray painting
Re: Spray painting
Howard Acheson
Yup, airless is what you want to use for house paint.
Another issue, have you removed the existing finish? What kind of condition is it in? You want to get down to base wood if at all possible.
If the existing paint is older than the mid 1970's, it in all likelihood contains lead and must be treated accordingly.
Re: Spray painting
Strip First
Shutters do well after a trip to the strip joint.
HVLP is great for finishes (rather than "paint") but a HF set will have trouble atomizing a heavy-bodied paint, even if thinned.
The suggestion for airless are good. Most paint stores have equipment you can rent, clean, and take back. I know several gents who like the hand-held Wagner "Powerpainter" gun units, but I've never used one so can't add on that.
