Delta 50-345 universal mobile base hardware kit
Charlie Lenz
This brand and model of mobile base is my favorite because I can build it just about any size that I need, and I think that the hardware for it is pretty heavy duty. If I sell a piece of equipment that it was on I don't have to let the mobile base go with the machine, I can keep it and resize it for another machine. Anyway, I need a mobile base for a Delta DC-33 Thickness Planer and stand that I just bought recently, so this weekend I started the project and now it's done, all I need now is for the paint to cure up a little longer and to get a friend over to help me get the very heavy Planer onto the base. Delta says that you can use 1 1/2" X 1 1/2" hardwood rails ( not included ) to build the base, and I have done that before, but for the same price as hardwood or cheaper, I can buy a more durable and probably stronger 14 gauge steel square tubeing, so thats what I did. Then I cut it all to length, laid out the bolting locations, drilled them, then mixed up a small batch of Sherwin-Williams DTM paint to match the Rockwell gray, painted everything, and let it sit for about 24 hours before assembleing.
The last bad one I had I cut up and rewelded into something that would work under my lathe. The rectangular geometry makes up a bit for the really cheepo casters.
