THE WOODRAT IS BACK!
Storage building for lumber
Al Stokka - Cambridge, Iowa
Good afternoon,
I've been thinking about erecting a building in which to store lumber and would like to hear opinions on construction considerations.
I have been storing my lumber in the loft of a 1920's barn. I'm getting too old to be hauling lumber up and down a ladder so I've thought about building something on the size order of a double garage. Probably with an overhead door so, one day, a vehicle or vehicles could be parked in the building.
I could, but would rather not, due to the expense, heat/air condition the building, but is that necessary for lumber? Do I need to ventilate the building? The lumber I have in the barn is air-dried (for about 5 years) so, I assume that wood won't be losing any moisture in a different building?
What about floor material? Normally I would pour a concrete slab on grade, but need I be concerned with moisture migrating up through the slab? I guess I could install a polyethelene sheet under the slab?
If I were to store kiln-dried lumber (6 - 8% moisture) long term (3 - 5 years or more) in this garage in this climate (center of Iowa) what equilibrium moisture content should I expect to see in the future?
Any other thoughts on a lumber-storage building?
Al
Re: Storage building for lumber
Since you have a barn already
Gary Smyth
I'm thinking that it would be far less expensive to install a hay bale conveyor. I don't know the circumstances but it seems like you have plenty of space to put it. Failing that, perhaps a steel beam could be installed at the ridge and a winch and traveler used to lift and pull in lumber through the upper level loft door. Those would require two people at least. For one person for less than $6K you could rig a garage auto lift like they have in repair shops and turn it into a lumber elevator. That you could control with a push button control and enjoy the ride up. It won't be code, but I bet it works. If you really just want an outbuilding you won't need doors, just a tin roof and whatever sides will hold back the wet. A concrete pad will help too..
Harry Ludke
I also store my lumber on the second floor of my barn. The lumber get put up their thru the hay door at the end of the barn. For easy access, I build a wide and gently rising set of stairs with a full hand rail against the wall. Would that work for you? Sure would be much less expensive. I can also see building a chute near your lumber stash to bring down the lumber that you might need.
I find that the second story of my barn is ideal for drying green lumber. Lots of room to sticker up the lumber, good air flow and warm summer temps to accelerate the process.
C Pearson
If I had a barn and was sick of hauling lumber up to the hay loft I would buy a small used tractor with a bucket lift capable of mounting pallet forks.
Re: NEW Storage building for lumber
Harry, Gary,
I didn't mention, though it seems I should have, that the barn is not in the best of shape. The former owner used the ground floor for grain storage. Have you ever seen what happens to the concrete sub walls of a building when it is filled nearly to the ceiling with grain? It ain't pretty and makes repair very, very expensive. The foundation walls are bulged out and cracked. Also, the wood siding has not been maintained and the framing has deteriorated due to moisture infiltration. To save the barn, the entire structure would have to be lifted and a new foundation installed after removing the old concrete. Alas, much as I love old barns, I don't think there is much life left in this one.
Hence, the reasons for my questions about a new building.
Al
Bill Tindall
Probably with an overhead door so, one day, a vehicle or vehicles could be parked in the building....I recommend swing out doors so the racks can go to the ceiling. An overhead door occupies valuable space. The swing out doors are trivial to make. Make a frame from 2 x 2 lumber and sheet each side with plywood or composite of some sort. Then hinge door to frame with butt hinges. to frame. Can replace with overhead door down the road as needed.
I could, but would rather not, due to the expense, heat/air condition the building, but is that necessary for lumber?.....no
Do I need to ventilate the building? ....doesn't matter one way or another.
What about floor material? Normally I would pour a concrete slab on grade, but need I be concerned with moisture migrating up through the slab?.......no. Put a sheet of plastic over the concrete and raise the fist layer of lumber up off the floor with 4 x 4/s so air can get under the stack.
If I were to store kiln-dried lumber (6 - 8% moisture) long term (3 - 5 years or more) in this garage in this climate (center of Iowa) what equilibrium moisture content should I expect to see in the future? 6 to 12 % depending on time of year.
Any other thoughts on a lumber-storage building? The most important requirement is to keep the dust out. Leaky barns are awful places to store lumber. Invariably the lumber gets covered by a layer of planer blade eating dust. Put a door in the gable. It isn't handy, but you can put small quantities of less than dry lumber up there on the ceiling joists in the summer and it will be KD in a week.
wooden leg
If I was to build a building to use as storage for lumber, I would to the following:
1. Cement floor with moisture barrier. 2. Install lights just in case you use you need them. Overhead door to make it easier to unload or load lumber.
I would go to the local lumber yard, they usually have plans for buildings that are close to what you want at a price thats cheaper then you buying the lumber has you build. Dave
Yonak
Al, I don't know if this is over-kill for your needs, but when I built a lumber storage building, I was also concerned with moisture content, especially since I intended to put in green lumber, as well as dried lumber. I installed a passive, low-energy solar-kiln-style setup. I put four glass panels in the roof (protected from falling tree branches) with encased, black cellular foam beneath as collectors and thermostat-controlled low flow fans to circulate the heated air through chases, distributed at floor level. It works much better than I anticipated, especially in the high-humidity warm months.
Otherwise, perhaps you could, at least, think about a dehumidifier.
Re: Thanks all. Very helpful.
