THE WOODRAT IS BACK!
Three Legged Stool
Three Legged Stool
Three Legged Stool
skirincich
Hello,
A couple of years ago in Popular Woodworking Magazine, Robert Lang described the construction of a Chinese three legged stool. It looked like a nice project, and eventhough the joinery looked to be somewhat complex, I figured that I would give it a go after reading the article at least a half-dozen times. I have posted a picture of my progress, and I would like to here comments from others including those who tackled this stool. Thanks.
Steve
Re: Three Legged Stool
I don't like sharp edges. They cut into the legs. I think that if you were to ease the edges, it would sit a bit better. Your choice about the stool legs - you can ease the edges or not.
skirincich
The picture shows that the joinery is far enough along to make assembly possible, but the legs and seat are not yet finished. The sharp edges will be softened and the legs will be slightly tapered. The seat will be round with a slightly concave upper surface. For those interested in structural details, I have provided a few links.
The stool project fascinates me because it is relatively small, contains only seven parts and seems to be a good target for a mostly handtools approach. The angled mortise and tenons linking the seat to the legs are straightforward, but the stretchers present a number of challenges. The stretchers meet to form a triangle under the seat, but because they do not radiate from a common centerpoint underneath the seat, the joinery linking the stretchers to the legs is a bit tricky. In addition, assembly of the stretchers has to be done carefully, and coordination of the final asssembly and glue up must be considered beforehand. For the Sketchup inclined, examination of the stretcher tenons going into the legs requires a slight angle that can prove troublesome (as noted by Robert Lang) if parts are not carfully labelled.
Steve
Online Project Discussion:
http://www.popularwoodworking.com/woodworking-blogs/editors-blog/chinese-stool-2-popular-woodworking-editors-0
Sketchup Link:
http://sketchup.google.com/3dwarehouse/details?mid=e18fae5fcce59dcf310af74324aae27f&prevstart=0
Gary Smyth
I bought a similar stool on ebay several years ago. It disappeared (likely to a different office) quickly. What I do remember is the all of the connector joints used wedged tenons which made things easier to fit. Mine was made probably by the shipping container load - hundreds turned out daily. Off of your post one pic shows that the tenons are angled. I didn't realize that on my purchase. I thought that the wedge was angled on its side to fit the gap, it tightened the joint, and that the tenon was straight
