grinders 4 sale
paul woelper
does any body happen to have a 8 in. baldor grinder they want to part with? Or maybe some ideas on a good alternative?
grinders 4 sale
paul woelper
Re: grinders 4 sale *LINK*
Bart Goldberg
The one I have (link below), I purchased several years ago and use mostly for sharpening my turning tools. I've seen it on sale for around $100.
Slow Speed Grinder
Grinder thoughts *LINK*
David Barnett
If you've never owned a Baldor bench grinder, you're perhaps fortunate as you may be happy enough with alternatives. Since the Swiss bought Baldor, don't look for lower prices to return.
As for speed, I'd opt for the 1725/1800 rpm motors. I used to have a light touch on the higher speed grinders but I feel more secure with the slower speeds nowadays.
Baldor's bearings, the sheer mass of their castings and high quality components are not matched by cheaper, lighter grinders but you can do things that can make them more acceptable, such as good mounting, heavy bases, aftermarket toolrests, and wheel balancing, which is a good idea on any grinding wheel for my money.
As for wheel diameter, you didn't ask, but I use and recommend 7" wheels, which I feel are the optimal diameter for most tools in a home workshop, both for grinding woodworking tools and metal toolbits. 6" is, for me, too quick a curve for tools I make and grind, especially for the small metalworking lathes I favor, and has a slower rim-speed than the 8" wheels.
An aside: Depending on your grinding needs, if you don't really need hollow grinding, for example, consider a 1" x 42" belt sander/grinder with a 1725 rpm motor. Lee Valley carries the Viel (vieltools.com) at a very fair price (sans motor). One thing, for most sharpening, wire the motor to run clockwise (running the belt upward from the toolrest). These are great tools with all kinds of uses, from sharpening and shaping tools, to sanding and shaping wood and other materials (slack belt), stropping and polishing. You can even use the top idler as a contact wheel. Great for spokeshaves and drawknives, too. The 1" belt sander is terrifically versatile and the most used generalized power tool in my shop, although I have the 3-wheel Delta version.
But there's a lot of price between any Baldor and Bart's suggestion, so by all means give others a look. If you can live with a faster wheel speed, I've heard fairly good things about Palmgren's 7" grinder at about $185. Seems heavier than some and with balanced wheels, I'm told it's a reasonable compromise.
So if quality's your thing, Baldor. And if you can find a used Baldor, or older Milwaukee, Delta or vintage Sears, I'd say jump on it. If I lost mine, I'd buy another Baldor, but I'm spoiled by now.
Lee Valley 1" x 42" belt sander/grinder
Re: grinders 4 sale
Jason Waters
You will be a lucky individual to find someone willing to part with a baldor grinder!
I see some 3 phase ones come up now and again, but rarely single phase.
But hey, it's worth a shot.
Visit (or call) your local Baldor dealer. If you are lucky, and he's having a bad sales month, he'll move one cheap.
Jason
Re: Dayton 8" bench Grinder
Charlie Lenz
This is the closest thing I can think of to a Baldor. I stumbled on it a couple years ago in a local ad. http://vintagemachinery.org/photoindex/detail.aspx?id=8579 Grainger sells Dayton if your looking for a new Grinder.
Re: Further comments to what David suggests
Charlie Lenz
I have had a older made in the USA Delta 1" belt sander http://vintagemachinery.org/photoindex/detail.aspx?id=11580 I bought it used for $100 a couple years ago, I like it alot and I use it more then the Dayton 8" Bench Grinder that I have. I tried two used older Emerson built Craftsman 1" belt sanders and while they both appeared to be in good condition, they were both wore out, I would not recommend them. If you'd like a new made in the USA 1" belt sander with from what I can tell has a Baldor motor, I would suggest trying the Kalamazoo 1" belt sander http://www.kalamazooind.com/products/belt-sanders/1sm-belt-sander/ Enco has them for about $220.
That's a great sander
David Barnett
MIT has one in its AI prototyping lab with the Rockwell machined metal drive wheel and idlers.
The Kalamazoo, a favorite of custom golf club makers, is the upscale version of the Viel that Lee Valley sells. The street price of $220 is amazing as that's not a lot more than the Baldor motor supplied with it. Great suggestion.
Re: grinders 4 sale
John in NM
I have a 6" Rockwell I paid about $30 for. Seems like you can get really nice old grinders for not a huge $$$ if you have a used tool vendor around. Kent's in Tucson used to be my regular haunt, and there is a similar shop in Albuquerque that I go to now and then (the owner's knowledge and inventory cannot rival Kent's though)....
Generally I stay away from pawn shops, I've yet to find one worth the time to go into. Tools are either cheapies or rode hard and put away wet, and they still seem to be awfully proud of them.
I think if I were going to spend the money on a Baldor, I would find a nice big 3 phase grinder and run it through a VFD.... only downside to that kind of set up is buying the wheels
