What is "nested-based manufacturing"?
Bill Tindall
It seems to have something to do with the manufacturer of furniture or kitchen cabinets. I encounter the term in the trade literature.
Re: What is "nested-based manufacturing"?
Brian Aust
My Google-Fu has discovered this:
In a company set up with a Nested-Based Manufacturing cell, the sheets of material are placed on a CNC router and all finished components are machined complete in a single setup, without any material handling. The CNC router sizes, machines, rabbits, dados, grooves, bores, shapes, pockets and performs any other operation required on each part in the nest!
Thomas S Stockton
Bill
Brian has the basics, mostly used in cabinet type construction. Saves a lot of time since all the machining is done on one machine and the operator can do other tasks while the panel is running. I'm sure they make automatic loaders and unloaders also and bar code readers to tell the next machine what to do.
Tom
Moses Yoder
Re: Alternative
Moses Yoder
The alternative to nested based is to use a beam saw or sliding table saw to cut all your parts to size then put them on the cnc for machining, plus you have specialised machines for things like line boring possibly and doweling in the edges or rabbeting for a back. This is actually faster, because in nested based you are limited usually to one $250K router, and you have to wait for it to do the entire sheet before you can put on another sheet. In nested based, in order to increase production you have to buy more routers, where with a beam saw and point to point router all you have to do to increase production is add small 10-15K machines.
This is all very handy to know if you are going to make frameless pieces of crap by the thousands and hang them in somebodies house and call them kitchen cabinets.
Re: Alternative
Bill Tindall
I still don't understand what the "nested" means but now I understand the context of the article that said this technique would enable to US manufacturing to be competitive......apparently competitive at the most bottom end of Ikea furniture and cabinetry.
There was a discussion over on the hand tools side that involved whether people appreciated finely crafted furniture. We had dinner guests last night and they were examining a chest of drawers I had made. The husband pulled out a drawer and then slide it back in, silky smooth and effortlessly. He called to his wife to "come try this drawer". (Of course at the glacial pace I make things he couldn't afford it even at minimum wage.)
Re: Alternative
Bill, I believe the term "nested" refers to the fact that several components - doors, cabinet sides, shelves, etc. are all cut out and machined at the same time from the sheet of material. The individual components are considered "nested" inside the sheet (although the sheet edges may have been removed during the operation). This is common in waterjet and laser cutting of metal components that I was familiar with in my previous job. Often a computer program insures that very little of the material is not utilized. Often this type of manufacturing is done using automated robotic unloaders / collators that stack the components or move them to a conveyor or machine etc. for the next operation.
thanks, that helped
Bill Tindall
At IWF I saw a sheet of MDF machined, glue applied and then folded up into a cabinet, so I guess I saw an example.
Re: Alternative ( Bill Tindall )
Charlie Lenz
An here I thought that I was the only one that works at a glacial pace.
