Undoing an epoxy glue joint
Dave in Bryn Mawr PA
I used epoxy to glue a broken chair stretcher and clamped it. Well the clamp slipped and the joint is now out of line. What to do?
Thanks!
Thanks!
Re: Undoing an epoxy glue joint
Try dry ice. Freeze it, thaw it, freeze it, try to crack it. Repeat as necessary.
paul woolson
Epoxy has a creep temperature of 140°. So heat is your friend here. A heat gun on low (so you don't scorch the wood) will do the trick wonderfully.
Dave un Bryn Mawr PA
I love this. Wonderful things about woodworking is that there so many ways to the same thing, and we all have our favorites. For example, I have received two responses to this question: one says COLD and on says HEAT! Well, I'll try both.
Just the opposite
Howard Acheson
The shop I owned did lots of marine work. We used lots of epoxy and had to open hundreds of joints glued with epoxy. All the chairs we manufactured or repaired used epoxy.
We used heat. Typically we used an infrared heat lamp with the lamp 6-8 inches away from the joint. When the epoxy softens, give a whack with a dead blow hammer and it should come right apart. I've sometimes used a heat gun but that can be too hot.
Keith Newton
Dave, Heat is the best answer. A piece of hose on a tea kettle can eliminate any possibility of scorching associated with dry heat.
Re: Just the opposite
Ditto what howard said. I have released a lot of joints using heat.
