wooden wheelchair
wooden wheelchair
Jack Guzman from Maine
wooden wheelchair
A friend gave me a wheelchair that was rotting away in her basement. It has an oak framed seat with woven cane. I want to restore it. It's still all there and functional. It just suffers from being in a damp area for too long. The only part that I can see being troublesome is the wooden handrims on the wheels. They have lost their roundness,come apart at the joint that joins the ends of the hoop and split in several spots where the grain runs out. I think the best bet is to try and replace them.Does anyone know of a source for such an item? I have all the hardware,I just need a wooden hoop.
If I can't find replacements I'll probably build a steam box shaped to fit them and try to rebuild them around a form of some kind.---Jack
Re: wooden wheelchair
Dick Coers
I would be tempted to do a lamination for the rim before I would try to steam bend. Just me, but I wouldn't have much confidence about getting a true circle from steam bending. You know, springback and all.
steve mackay
Hey, sounds like a VERY cool project !
If I do go that route,I will just reheat the old wheel and try to do repairs on a round form. I'm not sure about glueing a piece of steamed wood though. The steam box will have to be built to fit the hoop shape.I may try it anyway. Sounds like a fun project.---Jack
Joseph Mulherin
Jack, instead of trying to make the hoop in one piece steamed....divide it in two pieces and use some dowels bought from HD or Lowes, steam them to fit your form, let cool for a couple days, then scarf the ends so they mesh together with little or no noticable edging in the joint and epoxy them. That way you already have smooth loops and very little sanding to do for finishing. Stain them and cover with a few coats of poly.
I may try that. I'm going to have to do some experimenting .---Jack
Joseph Mulherin
Jack, when scarfing the joints use a small pin to connect(small wooden dowel) , make sure things fit together dry before epoxying for the finishing.
thanks
