Router Table Fence
Router Table Fence
Router Table Fence
Tom Rex in TX
Does anyone have or know where to get detailed plans for an excellent router table fence with micro adjustment?
Re: Router Table Fence
Re: Freud Router Table Fence
Charlie Lenz
For less then $100 the Freud is hard to beat if thats what your looking for. I have one and I like it. But I'm not exactly sure if thats what your after other then plans. Were you looking for something similar to the Incra ?
Tom Rex in TX
I'm looking for one that I can build myself.
Gary Smyth
ROUTER TABLE MICRO-ADJUSTER
www.woodsmithshop.com/download/207/micro-adjuster.pdf
You can peek at the one above offered on the net.
In my experience you don't really need a micro adjuster. As long as the fence is substantial, perpendiculer to the table, free to move, and can be locked down (I use a slot and plastic knobs, fender washers, with a 1/4" stud, and insert permanently set in the table) you can eyeball and then run a test piece. It's just as fast and accurate and there is no futzing with screws and springs, etc. And since the wood passes the cutter on a single point throughout the pass, the fence doesn't always have to be parallel to the miter slot (unless you are using the miter gauge to hold the piece to the fence). Oh. and since I laminated a white piece of formica on the top when it was built, if I have to duplicate a cut or just play with it a bit, I draw a pencil line on the top and use that as a base point to make further adjustments. I use soft color pencils on occasion to keep track of the "correct" line if I have to go back after an initial setup.
