Worktable height, thickness
I'm building a worktable for the playhouse.
It would be used to assemble "flats" and scenery. It would also provide a surface on which to cut things (shapes).
Nothing fancy, basically sheets of plywood with aprons. I'm building sawhorses to act as "legs" rather than have attached legs. The tops would not be permanently attached, but removable.
I basically want to have two tables made out of 4 x 8 sheets of plywood. My current thought is to use 3/4" thick plywood, but I'm amenable to using thinner plywood. I was going to have an apron made out of 1 x 4 with three cross braces running across the width of the plywood.
While I prefer a taller work surface, I realize that some of the people who volunteer at the playhouse are not as tall as I am. I was therefore going to make the sawhorses about 30" tall. That way the worktable height would be on the order of 30 1/2" to 30 3/4".
So - thickness of plywood - should I use 3/4" plywood or 1/2" plywood?
Worktable height - should I make the sawhorses (which may be used as sawhorse on occasion) 30" or what?
TIA.
Re: Worktable height, thickness
If I were to make these I would fabricate torsion boxes, a couple of thin sheets 1/4 or maybe luan with 1 x 3 or 1 x 4's would make a very strong stable worktable which would still be lighter than the 3/4 with aprons and far less likely to warp. I fabricated one for a friend a year or so ago to be used as a model train layout. Worked out quite well. You could probably install folding legs - possible inset a second group a few inches inside the first four - making 2 different lengths of legs for different heights or maybe someone has a plan for adjustable legs.
AZ in Colorado Springs
Consider the weight of the work top and how often it will be moved Thicker plywood will be heavier. (And maybe more stable.)
My own work bench is 1/2" plywood, with a grid of 1x6s -- around the rim, one lengthwise down the center, and two going across about 18" or so from the ends. Similar to a torsion box, but no bottom side. It's plenty rigid. The legs are 4x4s, connected with lag bolts, nestled in the corners where the crossmembers meet the rim boards. There also is a lower shelf, made of a 1x4 "collar" and 1/2" plywood, to provide storage and stabilize the legs (also secured to the legs with lag bolts). The size of the top is 3' x 5'.
I made it this way in 1985 so it would be portable (dis-assemble-able), as I was starting out an Air Force career. Took it with me all over the country to ten different houses, and still use it every day.
The only thing I would wish was different is using 1x4s around the rim (would be easier to clamp items to the top), but 1x6s provide more support to the legs. Also, without a continuous bottom side, clamping is limited to just around the edge (similar to the problem of the underside of a cast drill press table, but with deeper recesses).
For a 4'x8' work table, I'd think 1/2' plywood with a frame of 1x4s beneath the table, with one lengthwise down the center and a couple of cross braces (in addition to the outer rim) would be sufficiently rigid, unless you foresee putting some very dense items on top.
Yonak
Wouldn't it be cool to make these work tables with walking legs ? That way, one person could move them, with stuff on top, without removing the tops. Now, I don't know if they would be sturdy enough for your purposes, and I'm sure it would involve significant engineering and plenty of work, but it may be workable for your needs, and it might be a fun project. (Of course, there's always casters too, for the unadventurous.)
