Stabilizing a stress fracture
mdclor
I just discovered that there is a stress fracture in the end of a table top I made. I don't know how I messed it before glue up. :\
Can I mix a two part epoxy and let it run down into the fracture to prevent it from growing? The split is about an inch long and less than 1/16" wide. It does not go into the top or bottom that I can see.
Should I try to color it black or just let it be clear? The finish will be TransTint Dark Vintage Maple dye with 3 coats of Target EM6000 over it.
Any other thoughts or suggestions?
TIA,
Merle
Re: Stabilizing a stress fracture
Dale Lenz
Sounds like....
Dale Lenz
honeycombing to me, a drying defect. Anyway, I'd use blacken epoxy more-than-likey. Be on the look out for more, I use super glue on surface cracks that surprises me.
Bill Tindall
Is it not just an end check that did't get discovered? Given my frugal utilization of lumber I live in constant fear of these undetected end checks. You may have some luck wicking thin cyanoacrylate adhesive into the crack. It will wet to the end of the crack and may prevent further propagation. Happily end checks do not typically propagate at this point.
Beyond that I can only offer sympathy.
Re: Sounds like....
Bill Tindall
If it was honeycomb I would expect that this piece of lumber would have been under stress and greatly misbehaved when working it, which would have set off alarms.
What species it it? In the thousands of bdft of lumber I have handled I have only ever seen honeycomb in oak, and then very rarely.
Re: Sounds like....
mdclor
It is qswo. I will try some cyanoacrylate adhesive. It is so small and on the end of a sofa table so I think I won't worry about the color. I will be happy to just keep it from growing.
agree with Dale
Bill Tindall
It is probably an isolated honey comb fracture. They form to relieve stress so with luck the stress is gone and the crack will not further propagate, and indeed that has been my experience. If the crack doesn't reach the surface the finish will not suffer. Treating it with cyanoacrylate adhesive and filling the void will probably yield a perfect repair.
This sort of crack is easier to deal with than an end check. While end checks don't continue to propagate, seasonal changes expand and contract them and they tend to crack the finish over time. Sometimes cyanoacrylate adhesive will stick the two parts together and prevent this finish-cracking movement.
Call your Dr.
Don Orr
Oh wait, not that kind of stress fracture. I work in radiology and think bones first. :D ;)
I would color the epoxy but a trick I use is to make it translucent. don't add too much color. What you want it to do is pick up some color from the existing wood. I do that to fill in cracks in knots and such. If you heat the epoxy it will flow into the crack better and go deeper into the real parts of the crack. The downside is it will also be quite runny so you have to contain it some way. I use blue painters tape if I can. If that won't work I use clay and make a sort of Dam to hold it in place. If you apply some finish before you start the clay won't leave a mark.
mdclor
I bought the CA glue today. I will let you know if it has stood the test of time in a couple years or sooner if it doesn't. :D
Again, thanks for the input.
