Re: O.T -220v/110v Converter
dpcastor
Check the information on the chargers. Many of the new electronic chargers are auto-ranging and can handle 120 or 240V automatically. If this is the case with the ones you have, you just need a plug converter to adapt the US-style 120 V prongs to fit the Euro 220 V outlets.
If they will only work on 120 V, you'll need a small 220V-120V converter with a large enough power or VA rating to handle the chargers. But these don't draw much power, so it won't take much.
But the curling heat contains a heating element and draws a fair amount of power. A transformer-type converter is probably required to convert the 220 V supply to the 120 V power needed by the heating element. If you plug the curling iron directly into a 220 V supply, it will likely have brief exciting life.
To be honest, I'd suggest you just buy a new curling iron when you get there if you have to have one, rather than lugging around a converter.
Dave
