Cabinet Saw Cabinet
Cabinet Saw Cabinet
Cabinet Saw Cabinet
Allen Bryant - Bumpass, VA
I've been saving for several years to upgrade my contractor saw to a cabinet saw. My current contractor saw is mounted in a custom cabinet that combines dust collection, mobility and storage under the right side of the saw. I have a 52" fence on that side. The cabinet saw is a different beast, but I also would like to put something under it to make use of the space under the 52" saw. Has anybody else done this and had any problems, for one the cabinet saw is going to be much heavier, so caster's will probably need to be bigger than the ones I have now.
Re: Cabinet Saw Cabinet
Jason Waters
I have a Delta Unisaw with their mobile base. Mine is an older model, but I have a 50" tableboard, and the base had a piece that bolted on to hold the legs for the 50" fence and board.
I then build drawers to hold variouse blades, etc, that reside under the far right side.
But I rarely move my saw.
Re: Cabinet Saw
Hi Allen,
First thing I did when I got my cabinet saw was to weld up a mobile base frame. I then used that and the extension table supports for some shelving (usually collects stuff I don't know where else to put). Since a cab saw will have a DC port built in, you won't have that chore. I've seen, however, guys make very elaborate cabinetry with fancy drawers, router tables, (and once a small refrigerator!!) built in under that area.
Re: Cabinet Saw
With the main part of the temporary shop, which is becoming all too permanent, being 16x14, I can move stuff into the main part of the garage for temporary work on large projects. I have to make use of every space I can. There is a large amount of storage underneath the tables of cabinet saws if used correctly. I'm not sure how I'm going to organize it yet, but it still has to be mobile.
Re: Cabinet Saw
I was at Dempsey's in Richmond the other day and he has at least one used Unisaw and several others that might fit your bill if you are looking to get one Used. I was tempted, but did not ask the price.
Re: Cabinet Saw
I'm not against used, but part of the deal with the wife and she has a good point about space too, is that I have to get ride of the contractor saw before I can purchase the cabinet saw and I haven't had the chance to get it cleaned up to see what I could sell it for.
Jim Dillon
Allen,
Here, hopefully, is a pic of my setup. It is crude, but extremely useful if for nothing more than a convenient place to store the regular fence. I keep other custom fences on the lower shelf, plus the blade changing wrench and board for locking the blade on the top shelf. The shelves could be longer, but I have a table-mounted router taking up space on the far end. Works for me. Oh yes, the cabinet saw is on a HTC mobile base that is easy to move though I seldom do.
Jim
How do you have the shelves attached? Are they suspended from the table?
Jim Dillon
Hi Allen,
The TS extension framework is made from 1x4s on edge. The top is made from 3/4 inch MDF. There are several cross-braces (also made from 1x4s), especially surrounding the router cutout. Sorta like the innards of a torsion box with only one side, the top. I fastened four vertical 2x4s to the cross-bracing and joined those with horizontal pieces of 2x4. The shelves are just laid on top of the horizontal 2x4s. I did not take the shelving all the way down to the cross-brace on the mobile base as I wanted room to clean under the TS. The shelving is open at both ends which helps accommodate my slightly longer fences. I hope this is somewhat clear.
Jim
