Shop improvements
Shop improvements
Shop improvements
gary camp Bend, Oregon
I am getting ready to upgrade my storage areas in my shop. One of the things I want to do is add some draws to what passes for a work bench in my shop. I have an old bar table made from laminated pine 2x's 8 feet long by about 30 inches wide setting on and old strudy cabinet, this works well enough for me for now. I also happens to be the same height as my saw table. I know I could do some research on the net and maybe find this answer, but I like to ask those that might know first. I would like to put in a drawer to hold my setup / measuring tools, I really would like to access this drawer from either side of the bench.
does anyone know of full extension drawer slides that would allow a drawer to open on either side? Thanks
glc
Re: Shop improvements
Re: Shop improvements - 2 Way Travel Drawer Slides *LINK*
Bob Entwisle in NJ
Gary,
I Googled 'Bidirectional Drawer slides' and came up with these, probably others if you search around.
Bob in NJ
http://www.drawerslides.com/c/two-way-travel-drawer-slides
Thanks Bob, sometimes thinking up the right name to search by is the key.
glc
mdclor
Gary,
Another thought would be to attach two square Z shaped pieces of metal to the bottom of the top with screws in slots to allow for expansion. Make your drawer box and cut a slot in each side to correspond with the bottom of the Z's. Slide the drawer back and forth on the Z bottoms. Does this make any sense?
HTH,
Merle
john Veerkamp
If the drawer is not too heavy, just plain old hardwood runners thru the carcass, with a double ended drawer.
periodically wax the runners and you're good to go. Cheap too!
I've thought about just using wooden runners. I'm sure "someone" at my house would pull the drawer all the way out looking for something and then have to pick everything off the floor, (probably that someone would be me) so I'd really like full extension slide.
Gary Smyth
I didn't know that they made two way slides. If you find that they work for you, then great. However, the slides are pricy but more importantly, take up a lot of space .85" on either side of the drawer. That is in addition to the drawer side thickness. The pic might work for you. My bench is built with an internal box frame that fits inside the legs. Built into that frame are permanent dividers that have dados in the stiles. The ½ inch plywood dividers go all the way across/through the frame. The drawers fit inside of the frame and rest on cross rails and slide within the divided sub frame. The drawers have 1/8 clearance on the sides so change in weather doesn’t affect the ability to slide. They save side space (a bit over 1 ½ “on each drawer (compared with 2 way slides) and even though the drawers tend to get quite heavy with stuff, in over 20 years, I’ve never had a problem. Once a year with silicone spray I pull the drawers and spray the inside of each cubby. When dry I reinsert the drawer and let them slide within their cubby frame. These drawers go all the way through and slide in and out from both ends. In theory they could slide out and on to the floor. Truth is that they never do in real use because when the “front of the drawer” is loaded, it’s easier to walk to it than to pull the drawer through to the “rear” (when standing on the other side of the bench). There most always is at least four inches inside the frame no matter which side I use. In all that time I can only think of one instance where unintentionally pulling through the drawer all the way out was when I wedged an item inside the drawer. I had to push rather than pull to release the offending metal stuck piece. When it released it went flying. Never in regular use though.
Thanks
Gary Camp, Bend Oregon
You all have given me some ideas
