hole saws or bits
wooden leg
I have several hole saws, they all take the same arbor. How do you store them? I sharpen them and then put them in a box. As always, thanks. Dave
hole saws or bits
wooden leg
Re: hole saws or bits
Tom Dunlap
My specialized drill kit goes in the bottom drawer of my stacker toolbox.
when I made the holesaw storage I set out all of them onto my workbench in descending size. About 1/8" between them. That showed me how big a base piece I needed. Then I cut a piece of ash that is thicker than the smaller diameter tang on the hole saws. Next I put the holesaws onto the ash and lined them up neatly. When I had them squared away I used a transfer punch to locate the holes. A trip to the drillpress and I had my base ready. There was extra space on the ash slab so mounted a small plastic box to hold the extra pilot bits and arbors.
Tom
steve mackay
Mine are all hanging on the peg board so as not to bang around. (no outlines please)
John in NM
I often nest mine and keep them in a tool box. I probably don't take as good care of them as some of you guys, because to me they are disposable bits and mostly used in construction (which will, I hope, be a temporary activity for me
Most of my big holes for woodworking are done with Forstners or big augers.
Cardboard box for holesaws, index box for bits
Kneale Brownson
I roll large bits and auger bits in oiled rags.
