Selling and storing stuff in plastic containers
Bill Tindall
It is common to believe that a plastic container provides a barrier to prevent stuff in the container from getting out, and stuff outside from getting in. This assumption is rarely true and in some cases this fact has some practical ramifications for woodworkers.
On the molecular scale any plastic is more or less full of open spaces, more than large enough for small molecules like oxygen and water vapor to pass through. How fast stuff diffuses through a plastic container depends on the thickness of the plastic, the solubility of this stuff in the plastic, the concentration difference of this stuff on outside to inside and a third factor that depends on the size of the molecules trying to get through the plastic. To retard the amount of stuff getting in, or out, of a container the container can be made thicker or the nature of the plastic can be changed to lower the solubility of the stuff in the plastic.
Some examples to illustrate the fact that plastic is a "screen door" to small molecules- Blow up a balloon with helium and the next day it will be largely deflated. The tiny helium molecules have zipped through the open space in the plastic(rubber). Coat the balloon with aluminum and the balloon stays inflated because the helium is not soluble in the aluminum and the open space in the aluminum is too small for the helium to fit through. A classic experiment is to make a fish bowl balloon from silicone rubber sheet. Enough oxygen will pass through the sheet to keep a goldfish alive . And then there is the fad of nitrogen inflated tires where the smaller loss of nitrogen is true but the benefit is questionable.
Meat is packaged in plastic designed to be a screen door to oxygen. The refreshment of oxygen keeps the meat red.
You will encounter all sorts of stuff packaged with an aluminum foil coating. The foil is there to prevent oxygen or water vapor from getting in, or out, of the package.
Another example is soda. Leave a plastic bottle of soda on the shelf for a year and it will be flat. The carbon dioxide on the inside starts out at 60 psi where as the concentration outside is essentially zero by comparison. In this situation the carbon dioxide rapidly passes through the bottle walls. For a long time soda was only available in 2 L bottles because this loss was so great that the shelf life of smaller bottles was impractically short (think surface to volume ratio for explanation). The problem with beer is the diffusion of oxygen into the container. No economically practical solution to this problem has been found in spite of zillions of dollars spent in the search. (beer and tomato products are especially sensitive to oxygen)
Oil based varnish, paint and stains cure by reaction with oxygen. Oxygen must be excluded from these materials in storage. The picture shows the result of storing some varnish in a plastic 3M PPS cup. The cup was deflated to displace the air above the varnish and sealed. Never the less after a few weeks enough oxygen has diffused into the container to cure it. (in this case the surface to volume ratio was especially unfavorable)
I keep a gallon bottle of regular(not crosslinkable) yellow glue for years, until it is used up. Over the years it thickens. It thickens because over the course of years water has diffused out of the container. Adding back a small amount of water now and then maintains its usefulness.
The bottom line- It is not a safe assumption to assume that plastic will be an effective barrier to the gain or loss of a small amount of small molecules like air or water vapor.
