challenges of refinishing plywood
Wayland
Hi Everyone-
I am in the process of finishing some cabinet doors and drawer fronts that are about 20 years old. They are made of ash veneer plywood and are edgebanded with glued-on strips of ash about 1/8" thick. they were originally finished with some sort of sprayed on acrylic lacquer and I don't think they received more than two coats. Very thin stuff, and not substantial enough to stand up to the heavy use they got in my kitchen. Anyway, the finish has yellowed substantially over the years.
To remove the old finish, I have been running the edges over a jointer, which seems to work ok. The problem I have is with the faces. I am using 60 grit stearate in a random orbital sander, and have found that it's difficult to control without going through the veneer. I initially used 40 grit and it really got away from me fast.
The problem is that the old finish has worn through and the wood has greyed in places. In some of those places that process has been followed by a good deal of dirt having been deposited in the pores. In other places, the finish has alligatored. The dirty places are the most challenging. The sander takes off the dirt and leaves behind nice clean ash--for about a half second. Then I'm through the veneer and into the glue layer.
The challenge is that ash is so porous. There are high and low places naturally in the veneer, i.e., places where the wood is relatively thick and other places where it is thin. Unfortunately, it's the thin places that are dirty and that need the most sanding.
I thought of chemical stripping, but felt that it would soften the wood so that the scraper would do the same thing as my sander. And this way at least I avoid the chemicals. I am afraid that commercial dipping would delaminate the plywood.
I'd be interested in any advice anyone who has risen to this challenge has to give me, including, if need be, to give up. My next move is to switch to 80 grit and turn down the speed of the sander, and proceed like an amorous porcupine.
Thanks
Wayland
Re: challenges of refinishing plywood
Jesper, Denmark
Jesper, Denmark
I would take one more step down the sanding grit range to 100 or maybe even 120 grit. Don't try to completely remove the old finish, just get to a smooth surface.
If you end up sanding through the finish in places, use a primer as the first coat. You may need to also sand the primer and re-prime.
For durability, my preference would be a final coat of solvent thinned polyurethane paint
I refinished our kitchen cabinets. They had been painted with either brown latex paint or antique white latex paint. The previous owners had painted over a polyurethane (or so I presume) finish.
Anyway, I used copious amount of Citri-strip. It worked reasonably well. Due to the porous nature of the oak, some of the paint pigment did make it down into the pores. However, I did manage to get the vast majority of the paint and underlying varnish off of the cabinets.
I don't know if this will work with your ash. The carcasses of my cabinets were red oak plywood and the plywood portion did come clean. I was using a plastic scraper and various grades of abrasive pads with mineral spirits.
A recommendation and a solution
Bill Tindall
The veneer was originally 0.025" thick before sanding. It would seem a hopeless task to try to sand the finish off with a power sander. I would chemically strip it, removing the stripping solvent and finish with coarse steel wool. Then I would hand sand as needed.
You must recoat with a non-yellowing finish for ash.
Alternatively, this sort of job is done now days with adhesive backed veneer. One just sticks veneer onto the cabinets and drawers. A cousin had it done with maple and it looked great even to my discriminating eye for finished wood .
Re: A recommendation and a solution
Howard Acheson
I agree with Bill. The only effective way to remove a finish is with a chemical stripper containing methylene chloride. Follow the directions on the label. It will not softer your wood.
Sanding has two negatives. First, you run the risk of sanding through the veneer. Second, sanding will not remove the finish that has been absorbed into the large pores of a wood like ash. Any residual finish left in or on the wood will make re-staining problematic.
Avoid sanding except for a light clean up after stripping. Sand by hand in the direction of the grain using 220 paper mounted on a felt or rubber covered sanding block--DO NOT USE ANY POWER SANDER. Sand in the direction of the grain.
Roger Peterson
Going through similar issue with stripping but involves stained oak plywood. I'm through most of the poly, but now where there were high spots in the veneer and I scraped off the stripper its taking/lightening the stain. Can I continue to apply stripper and lift the stain? I'm hoping to reapply the stain and still retain an even color throughout.
Any thoughts/experience on this?
Roger
Steve Schoene
Stripper will remove all the stain, up to a point. Many stains also have a dye component. Stripper may not remove all of the dye, but by stripping off oll the binder in the stain and top coat you make it easier to get at the remaining dye. To remove the remaining dye use a chlorine bleach (Clorox) being sure to thoroughly rinse off all the bleach.
Wayland
Hi Steve and others-
Thanks for all your advice. I should have mentioned a) that these doors are flat panels of plywood, and are not raised panel, and b) the original finish is clear varnish (no stain) which has yellowed over the years. But there is no stain per se to remove.
In response to your comments, I bought some Citristrip yesterday and have tried it. Initial results were only partially successful. It got most of the varnish off, but still left some. I now have a second coat of stripper "cooking" and will see in the morning how it worked out. My shop is at about 45 degrees in this weather and it seems better economy to let the stripper sit and do its stuff overnight than to pay to heat the shop. I've also decided that one technique that might work is to "stir the pot," i.e. while the stripper is in the middle of working, scrape it, turn it as you would soft dough, with a pastry scraper, in making a soft sweet bread, and then, using the same scraper, smear out the stripper over the wood again. This brings fresh stripper to the varnish surface, so that you're not relying on molecular diffusion through the varnish layer to get the whole thing stripped off. I also plan tomorrow as I'm rinsing off the stripper, to use a brush to get it down into the pores. I'll let you know tomorrow how all that worked out. One big looming remaining question is whether or not it will ever get dry enough to sand, even the minimal amount necessary (by hand) to smooth the surface. Today, even after 4 hours of post-rinse drying in the house at 70 degrees (well 65, anyway), the surface was sticky and felt like it would be impossible to sand. The stickiness was a result of the residual varnish; by that point the water had completely evaporated.
If this works, it will be better than my original sanding technique. At least the stripper did not loosen the glue joints or delaminate the plywood. The surface veneer layer seems well intact.
Thanks again for your ideas, and for introducing me to Citri-strip. I'd heard of it but had forgotten the name and was thinking only of the old methylene chloride based stuff when I thought of stripper. It's a lot nicer to work with than that stuff.
Wayland
Bill Tindall
You are dealing with the results of using a marginally effective stripper.
The cold temperature is an advantage for this job. The best approach is to get what you can off as soon as a lot is softened and then reapply stripper. Repeat until you have bare finish-free wood. Scrape what you can off and then remove remains with coarse steel wool.
If this is too tedious then use a more aggressive stripper, maybe at least for the last application.
