Stuck table pin on bandsaw
Thad Parker
I'm finally replacing the blade on a saw I've had a few months now and the pin won't budge.
Any tricks or advice on freeing a stuck pin from the table of a bandsaw?
It's a mid-century Delta 28-200 (if that matters)
~ Thad
Mid-GA
Re: Stuck table pin on bandsaw
Dave Peebles Lyons, Ohio
Hi Thad,
If you are talking about the table leveling pin, I would try a little shot of WD40 and try a little twisting motion with some vise grips. You may want to put a little duct tape on the exposed part of the pin to keep from messing it up.
Best wishes,
Dave
eliotandmax
How about applying some heat? Don't do it on my account, though; I don't know how heat affects cast iron. Just a thought. I've seen auto mechanics use heat to un-stick metal parts
Bruce, a MN Galoot
WD40 and vise grips are my recommendation, too. I have the same bandsaw, and on occasion, when that pin is stuck I will occasionally drive it in just a bit with a hammer, enough to free it up.
Jason Waters
Some pins have a hex shape, so you can use a wrench, if you do, use a tight fitting wrench. if not, or it's boogered up, use a GOOD set of vise grips. I sometimes wiggle the pin back an forth and tap the vise grips with a wood mallet. I agree WD-40, or better yet, Kroil is you have some. If not, get some the next time you go somewhere that has it. Also, Liquid wrench and WD-40 make their own penetrating oil as well.
Tapping it in slightly may help too, to break the rust bind, but I would try turning first. But don't hammer on it, i.e., not hard...
When replacing the pin......
Howard Acheson
.... only lightly tap the pin into the hole. Use a straight edge across the blade split to see if the two parts of the table are flat or in line. Once they are in line, don't tap the pin any further. It doesn't need to be driven way in.
get something better than WD40
Dick Coers
Try RustReaper, Kroil, or PB blaster. WD40 is way overrated but is so widely available, people try to use it for everything. It was invented to displace water (Water Displacement 40). Let the good stuff sit overnight. You could also place a small piece of dry ice on the pin to temperature shock it. Heat and a flat cast iron table may not dance well together.
Kneale Brownson
Kroil source *LINK*
Kneale Brownson
I have their squirt can and buy by the gallon
Kano Labs
Twist & shout worked...thanks all.
