trouble making a jig for 5 sided handle
eliotandmax
I just felt like making a five sided handle. I found out that it's not so easy! what I did was to square up a block about six inches long and drill a hole down the middle of it 1 1/2 inches in diameter. I then cut this block lengthwise parallel to the center line at the correct distance from the center line to create a chord on the hole circle of very close to 11/16 inches in length. I then turned a cylinder of just under 1 1/2 inches dia. to fit into the hole. (In other words the cylinder protrudes the right amount so that when cut even with the jig the length of the cord is 11/16 in.) This cord length is the correct length for a regular pentagon. Next, the jig was set up on a router table with a straight bit and a bearing to cut the protruding part of the cylinder to the first flat of the pentagon. The cylinder is then rotated so that the resulting edge lines up with the edge of the cutout part of the jig. When done five times a five-sided handle comes out. To tell the truth, the method didn't work so well with a router. So I tried it on the band saw. I had trouble with that too because the downward pressure of the blade tended to turn the cylinder inside the jig. I figured a way to keep it from rotating, and that worked better. But accumulation of slight errors caused trouble here too. I intend to keep at it. But there must be a better way! Any thoughts?
