Using a planer to remove polyurethane
Robert Christman
I am in the process of finishing my walk-up attic and have a chance to get some used maple flooring that is in good condition. The problem is that it was in an old school and has a thick layer of polyurethane (or something like it) on it that I would like to remove. Is it possible to just run it all through a planer? Will this ruin my planer blades or cause other damage? Thanks.
Re: Using a planer to remove polyurethane
Nat Robison
I've never done it but I've seen it discussed here and I think the consensus was that the planer is the way to go. I believe it will dull your blades but compared with every other method, it's the quickest and cheapest method if your only expense is a blade re-sharpening.
del schisler
it will dull your blades if the blades you use are double ended use the dullest one and forget it. Or if single ended and it will be like 50 cent's a inch to sharpen figure what your time is worth go for it ?
Removing paint with a plane has been discussed here and the consensus was not to do it because the titanium dioxide in the paint is VERY hard and will dull the knives quickly and badly. I don't know how hard the finish you have is. I would imagine there is some grit in it also. Still might be worth it.
Ron Jones
If that is old school flooring you can count on several coats of a finish commonly referred to as "gym seal". There will be at the least some sand like abrasive caught in the finish. I have held summer jobs of refinishing wood school flooring. Personally, that stuff would never see my planer. You will need to sharpen the knives or get new knives at the least. Just my opinion--quite possibly worth less than what you paid for it.
Charlie Lenz
If your going to lay it back down for a floor your better off installing it, then use a floor sander on all of it, not only will it remove the finish, but it will make all the boards flush to each other.
Wayland
Hi Robert-
I take no position on planer vs. sandpaper, but will only add that if you use a planer, set the depth of cut substantial enough that the knives hit wood as they enter and go under the finish instead of through it. Of course, as the knife emerges, it must of necessity go through the finish, but by coming at it from below, it cuts through it instead of skimming it, resulting in less dulling. I've had experience with this, taking about 10 layers of paint off of some beautiful old redwood I wanted to recycle. It cost me a set of disposable blades but it was worth it.
On the other hand, if you decide to sand, use either stearate or zirconium oxide paper. Carborundum will load up in no time and be worthless.
Good luck-
Wayland
Install it upside down?
DizD
Can you clean up the back side of the boards & just leave the finish in place?
Re: Install it upside down?
Charlie Lenz
I refinishes floors for a guy for about a year. The back side of solid hardwood flooring is recessed, you do not want to remove that, plus you will lose too much of the lip on the tongue and groove.
George Koch
Robert, I agree with Charlies earlier post. Install the flooring without removing the old finish. The floor sanding process, that has to be done after the installation, will remove any old finish and level the boards just as it does with any floor refinishing job.
