is there any use for a garage door opener motor?
Re: is there any use for a garage door opener motor?
John McGaw
Basis for a lift mechanism for a really big flatscreen television?
Wayland
Actually, I don't think a garage door opener could lift a heavy TV; the garage door has to be fairly well balanced with a spring before the opener will work. I assume in you question you are not referring to just the motor per se, which is, after all, just a motor. The motor, transmission, chain, track, and remote control, if that's what you're referring to, could, I think, be adapted to open and close the drapes over your bedroom windows, so your significant other could use it to open them when you sleep too late.
just the motor...
Jerry Gibbs
It is my understanding because this motor is meant to reverse frequently, it will not run long without overheating. I just have trouble throwing out motors. Jerry
Dumb waiter
Tom Dunlap
I remember seeing how someone used the whole mechanism as a lift unit for a dumb waiter. Does this stimulate any creative juices?
My version of saving things means that the stuff gets saved with like-use things. Motors are all together. When I need space because of having too much stuff I go in and reduce. Duplicates go first...a reversing motor has potential so it would have priority over a one way that takes up the same space.
Tom
Re: Dumb waiter
Grant Wilkinson
A guy on another forum, maybe Sawmill, used one to make a power honer. It was just posted a couple of days ago. The motor turned a jewellery makers abrasive platter.
Re: Dumb waiter
Gary Bindel
I knew someone who used a garage door opener to create a wheelchair lift.
