Re: Good For Styro
Sgian Dubh
"I haven't found a use for Gorilla glue that I can't do with wood glue or epoxy and either one is far easier to clean up."
John, your statement is a reasonable one, but it does depend on your gluing needs. There is, however, at least one circumstance I can cite where polyurethane adhesives come into their own, ie, bonding wet wood or wood that is only partially dry, eg about 22% to 30 or 35% MC, or thereabouts.
We use such glues on a pretty regular basis when building outdoor furniture or artefacts out of wood that is frequently on the wetter side, even near enough green during construction. The only glue that works satisfactorily I have found is one of the polyurethane glues. Purbond HB is one brand good in these situations, although it may not be available in the US.
It's not surprising that this is the case really as nearly every wood adhesive is formulated to work on dry wood. Dry wood by definition is wood that's been dried to 20% MC or below. All of the regular glues such as PVA, aliphatic resin, urea formaldehyde, epoxy, etc, used on wet wood will almost certainly fail, which I can anecdotally verify. On the other hand, the polyurethane types really do work in these circumstances. You'll see some examples of the type of constructions I'm referring to at this link. Slainte.
