OT - Plumbing Soldering Question
Ralph Lipeles
When replacing a valve I always used to unscrew the handle/stem so that the soldering heat would not damage the sealing washer. I have to replace a valve and am going to use a ball valve. Are there any precautions necessary when soldering the ball valve to prevent heat damage to the seal?
Re: OT - Plumbing Soldering Question
Nat Robison
I just did a quick google search and one site said to leave the valve open so the hot air can escape and also advised to heat the pipe and the valve, instead of just concentrating on the valve. I'm sure there's more info on the topic if you look.
If you're worried about your technique, I know that HD sells compression fitting ball valves.....at least the straight-thru ones. I've used them with no problems and can be removed and re-installed.
BilWil
It depends upon the valve. The ball valves with nylon seals should be soldered with the valve closed, while those with seals of a higher temp rating can be soldered with the valve open or closed. I have always put the tourch to the pipe just short of the valve so as to avoid any problems.
Given that you've properly cleaned and "greased" both the pipe ends and the valve that is put in the open position . . .
Apply your heat such that the flame cone is on the lip of the valve, but pointing away from the center of the casting. Move your flame around the casting to evenly heat the brass. Keeping the wire solder out of the flame, apply to the pipe/valve joint on the top surface allowing the metal to melt the tin down into the joint. When you get a drip starting at the bottom, flick it off with your rag, then reverse the torch and repeat at the other end.
Remember, only the solder inside the pipe/valve joint makes the seal. You can wipe a pound of solder around the outside and the joint will still leak if the pipe is not fully inserted into the casting with the joint properly filled. Remember to, the solder melts and runs toward the hottest point.
Wrong!
Jerry Nicholson
The solder melts and drips on the nearest exposed skin :D :D
Jerry
Y'know....
John in NM
Liquid nitrogen does that too (well, not the melt part) :D
Mike in NC
Sweat ball valves closed and gate valves open. And remember that once in use, always back a gate valve back 1/4 turn from fully open to prevent the gate from "fusing" to the valve body over time.
