We value your privacy.
MIL has asked me to repair a stool for her. The tenons have shrunk and come unglued. I have seen products in the past that look like foil strips with teeth on them that you put around the tenon to help hold in place when you re glue it. Or could I just use Gorilla glue and let that expand and fill the gap? Stool is store-bought, and lack of the right tools do not make new rails an option.
Forget the wood swelling liquid, metal grippers and gorilla glue. Here's what I did after seeing all of those methods fail.
I carefully remove the tenon and clean off any old glue. Then I clean out the socket, even drilling the hole slightly larger. I take a piece of clear soft maple and my sharp bench plane. I shave off some long fairly thick shavings. Then I coat the tenon with glue and wrap the shaving around the tenon, applying glue as I wrap it until it is slightly larger than the socket hole. I tightly wrap the wrapped shaving with as many rubber bands as I can get on it to "clamp" the shaving in place. Once the glue sets up I remove the rubber bands and carefully file down the tenon for a very snug fit. Then I apply glue to both surfaces (tenon and socket) and assemble the chair insuring that I place it on a level floor so that all legs touch while the strap clamp does its work.
I've had chairs repaired with this method last for years before needing additional repairs.
Lee has it correct. I have repaired several - I use a similar method to Lee's. I use my Dremel with a drum sander wheel to clean the hole and tenon, then wrap plane shavings around the tenon using either hot hide glue or liquid hide glue until it is oversize then either rasp or sand it down to a tight fit and glue it in with hide glue. I don't have a level enough shop floor, so I set the chair on my saw table to make sure it is lever while I clamp it tight. The great thing about hide glue is that it will stick to itself years later, making future repairs even easier.
When my spindles or stretchers are quite wide enough, I often use window screening material (fiberglass or whatever it is - NOT metal). I put it in the hole with yellow glue in a crisscross pattern (like a + sign). I make sure that there isn't a lot of glue too high on the piece that I'm inserting. I cut the excess screening material off after the piece is assembled.
Epoxy does not require good fitting joints, so bridging a sloppy fit makes it well suited for your need.
You can mix it up with some dust out of your sander bag, to make it thicker, and match the color, then over fill the hole, before inserting the primed tenons. causing it to squeeze out. That would be with tape over the holes, if they are through the top, with it upside down on the bench.
Not that I'm in the habit of making sloppy joints, but I feel confident that I could glue a 1" tenon in a 2" hole, which would be strong enough to break the tenon before the epoxy failed.
Agree with Keith. If you want the fastest/easiest way, that does not require disassembling the joint, I'd just fill the void with a decent slow setting epoxy.
My choice for a tight fit is to use a piece of veneer. Soak it in water so it bends easily wrap it around the tenon and clamp with tape. Remove tape and glue - hide glue is best. NEVER use gorilla glue!
Epoxy does not need good fitting joints. Just roughly scrap out the old adhesive. Use slow set, two part epoxy. Speed up the reaction with an infrared heat lamp or a hair drying--or just let it set up overnight. Keep it in a warm spot. All the chair repairs we did epoxy adhesive was used.
In our shop, we used epoxy on all new chair joints. It held up the best--we never had a failure. Failures in chairs--or stools for that matter--are very dangerous so you want to do everything you can to prevent them.
The fact that the joint(s) failed is an indication that the adhesive failed. Any PVA and most especially any hide glue is guaranteed to ultimately fail.
