Re: Mounting router in table
George Colonel's Workshop-Havertown PA
Good Evening Greg,
I had to do the same operation last weekend to my #2 son's router plate. He has a P+C 690. I had a set of brass template guides and one of then fit the opening of the insert plate exactly. I installed the router and base with guide into the insert plate and used double stick tape to prevent shifting. Then I took the assembly to the drill press and drilled through the holes tapped in the router base, using the exact diameter bit. This located the holes in the insert plate so it preceisly matched those in the router base. Flipping the insert base downside-up, I was able to countersink for the flat top screws. No problems: Everything fit as intended, and all was central to the router bit.
George
