Birch plywood
Birch plywood
Birch plywood
Jack Putnam
I am building an outdoor Kiosk and I was wondering if I could use Baltic Birch Plywood on the Kiosk? I thought that if I put a couple coats of outdoor paint and a couple coats of varithane to seal it that it might work.
Thank you for any help you can give me.
Re: Birch plywood
Re: Birch plywood
Carol Reed, Pahrump, NV
You could, but you could save a bunch by choosing plywood that is intended for outdoor use. The difference is in the glue used to glue the layers of plys together. Baltic birch plywood is prized for no void interiors, more multiplies of plys in a given dimension, and no unpatched 'holes' in even the 'back' side. That comes with a price. Your choice depends on your intention. Your finish likely would be the same no matter which plywood you choose. Exterior wood finishes should be pigmented, rather than clear, for longer maintenance free intervals. Pigmented means painted, which also means any defects in exterior ply can be filled with no noticeable final appearance. You will be happiest if you review your intentions and then make your choice. You might even save some money. :)
Re: Birch plywood
Re: Birch plywood
Dave Paine
As Carol mentioned, Baltic Birch ply is not made with waterproof glue. If a crack opens in the paint, water will seep in and the ply could de-laminate.
If you are going to paint, then get plywood designed for outdoor use, or the special MDF used for signs.
The paint should protect from normal UV/rain. I do not think the Varithane on top of an exterior paint would help, and may not adhere depending on the type of paint. I like Varithane, but it will not stand up long for outdoor use due to UV.
There are special coatings for outdoor use. One is made by a company called Sikkens, brand is Cetol. I use this on a mahogany side light for the front door. This lasts a few years before recoating. This is not available in the big box stores. Need to go to a paint dealer and it is expensive, but works.
Re: Birch plywood
Certainly...
John in NM
I've used scraps of BB in outdoor, unfinished applicatioins (temporary, only for a few years :D ) and it held up better than painted CDX in my view. I wouldn't hesitate to use it as you describe, the stuff is high quality, but not nearly as cheap as CDX.
BTW, don't run BB edges on your jointer, you end up with a corrigated blade. Glue in that stuff is HARD! :D
Re: Birch plywood
Re: Birch plywood
Andy Lincoln,in Dearborn MI
Jack,
See if your local lumberyard /plywood supplier has MDO in stock.
This is a paper-faced plywood that is used alot for highway/road signage.
It is made to withstand the outdoors,it is super smooth ready for painting.You may even find it pre-primed.It is available good 1 side or good 2 sides and in (atleast) 1/2" and 3/4" thicknesses.
I have no experience with Varathane in an outdoor application so I cannot comment on your finishing schedule.
Andy
Re: Birch plywood
Re: Birch plywood
Howard Acheson
Actually "Baltic Birch" manufactured in Finland is made with exterior rated adhesive. It's called Finnish Birch. Russian make Baltic Birch is made with interior rated adhesive.
I think you meant "MDO" Medium Density Overlay. That's the material used for exterior highway signs. MDF will not stand up to experior conditions.
Correct. UV will rapidly attack urethane resin finishes causing it to get cloudy then begin to crack and peel. I good exterior rated paint is more long lasting.
Re: Birch plywood
MDO
"Medium density overlaid" plywood is what you want. Even without paint, it will hold up in all kinds of weather. In my old shop, I had an exterior basement door made of redwood 2x4s with a 1/2" MDO skin on the outside. It never got painted, and the plywood was still in excellent shape 20 years later when the shop burned down.
MDO is more expensive than baltic birch, but it's the price you pay for the right material.
Re: Birch plywood
Re: MDO
TomD
As a general rule, if plywood has black, or dark purple glue it is waterproof. Marine means it has other factors that make it waterproof even when immersed long term. Most plies will survive long term out of doors if properly finished, but the requirements vary, for instance fir ply is very difficult to stop checking.
MDO is the winner, but I have never seen it on offer, and I scour ply sources pretty extensively for boat building. I assume we use it in signs, but it hasn't even shown up at wholesalers.
Just the other day I saw an MDF mentioned as waterproof or exterior, but I assumed it was a mistake, though the guy was making picnic tables out of it. I did notice as I got deeper into the site that most of his products were baltic birch.
http://www.mobileworkshop.ca/jigsawpuzzlefurniture/mdfpicnictable.html
