THE WOODRAT IS BACK!
Downdraft table "design"
I picked up a couple of squirrel cage fan motors from old HVAC systems.
I would like to build a downdraft table. I'm thinking about replacing the table on my table saw - that way I wouldn't have to lose any shop space.
These motors intake from the sides (or so it appears) and output through a flanged flat area.
Where are some reasonable places to put the filters? Should I put them to either side of the fan? Should I put them after the fan? If I put them on the sides, I was contemplating using several filters - two on either side and one in front of the output. Or should I just have two filters?
TIA.
Re: Downdraft table "design"
Kneale Brownson
Kneale Brownson
I recall looking at a table that had a pegboard-like top and a couple fans in boxes inside. The boxes were well filtered at their tops and there was a filter arrangement below the perforated top.
Charlie Lenz
I built a Air Filtration unit with a furnace blower that I kept when we had our furnace replaced a couple years ago. I places a filter on each intake side of the blower. I figured that it would be best to filter the air before it gets to the blower.
I also have a couple of furnace blowers with the idea of creating a down draft table. Was thinking of mounting the blower under the top. Considered a tray under the grid with the idea of letting it catch as much dust at it could. Then was going to arrange a bunch of filters around the fans to create as much surface area as possible on the filters to cut down on clogging. The Idea was it would function as a downdraft table and could be left running to work as an Ambient Air cleaner.
Years ago I made an ambient air cleaner out of a similar blower. Its a rectangular box with an approximately square base. Has the blower in the middle and filters on all four sides. Three of them filter the air on the way in and one one the way out. It works fairly well as witnessed by the amount of dust I vacuum and blow off it once in a while. It comes on with the lights in the shop and runs if I am in there.
While I was cyphering on the downdraft table above the motor in the old air cleaner croaked and I used one of the "new" ones to replace it. Came to the conclusion that the blowers were too bulky for the downdraft table and built it with a tray under the top and hook my DC hose to it. Leaves space under the tray for storage. I still have the other blower and am thinking of building another Ambient Air Cleaner. Would mount it near the ceiling in the opposite corner of the shop to whirl the air in a vaguely circular pattern.
mdclor
JL,
I spoke with my brother who is knowledgeable about such things. He suggested putting the filters upstream from the side intakes. That could be right beside them or if you build some sort of framework, put them anyplace that is convenient. In this case, perhaps above the cage. Do not put a filter in front of the outlet since that would reduce the CFM. These fans are designed to pull air, not push it.
HTH,
Merle
Gary Smyth
I can think of no advantage running dirt through the fan and filtering it at the output. I favor the filter(s) on air input side. On my version I tried higher end paper furnace filters and the air flow to the fan was restricted too much. The cheap less dense cardboard screen furnace filters only seemed to get the big stuff. I finally settled on fiberglas insulation held in a wood shadowbox style frame that opens and 1/2" hardware cloth mesh on the face. I can adjust for air flow by adding or subtracting the thickness of the insulation . And it's cheap. A broken roll of R19 insulation cost me less than $10 and even with regular throw away changes has lasted me years.
Alan in Little Washington (NC)
For some reason, it has become "fashionable" to make downdraft tables with a pegboard top. Engineering-wise, that is about the worse thing you can do since it severely restricts air flow. You want a top with as much open area as possible- more holes than frame between them. Often a wide open grid made with thin but deep pieces (for strength) is the best. You can always put a small round or rectangular board on it that bridges a few gaps if you are going to be sanding small objects.
Kneale Brownson
Re: Downdraft table "design" *LINK*
Kneale Brownson
I found a plan I'd bookmarked years ago.
Clicky
